Audio Setup Advice
Old Jan 31, 2020 | 03:58 PM
mcdc1224's Avatar
mcdc1224
Default Audio Setup Advice
First let me say that I have been on here for quite sometime reading post and gaining advice, and thanks!! I need a little advice on a setup I have currently installed.. I have a 2010 Street with a Metra-95 fairing running a Sony 7000 HU. connected to a TM400X4ad with two set of Kappa 62ix's and one set on Matts 601cx. I have a set of Kappas in the Fairing, one set in the rear pods......added a chopped pack with pods and lower legs... the Mmats in the lower legs. The sony is running the Kappas in the TP's on the HU rear channel and the tm400x4ad runs the Kappas in the fairing and the Mmats in the lowers. I am running the HP on the sony at 80 with the EQ custom set and the HP on the amp at 100. Questions, first, does this sound like the right path. Next question, I ended running the Sony on 4 ohms instead of 2 ohms because it sounded much better for some reason, even a loud as the two sets on the front from the amp. I setup the amp per the instructions for clipping and using the punch levels about half way up.. Everything seems fine, just wanted advice from those much smarter than me Thanks for any help
rblahetka
Audio Systems
Sep 10, 2019 09:08 PM
GunslingersNation1
Audio Systems
15
Sep 1, 2019 05:14 PM
Rckoutwurcokout
Audio Systems
19
Apr 3, 2019 11:09 PM
billablehours
Audio Systems
Jan 31, 2017 10:29 AM
Lsc8
Audio Systems
Mar 1, 2016 05:46 AM
