need advice
Old Mar 19, 2020 | 10:48 PM
BluemaxRG's Avatar
BluemaxRG
Default need advice
what's going on guys need some advice I got a 2019 roadglide and I found a brand new pyle marine 400 watt amp still in box after I moved and I want to use that on the bike but I'm looking for advice on what speakers to pair with it I think for now I'm going to go with just a 2 speaker setup and maybe down the road mess with bags (lower fairings are out for me)
my other question is what is needed to run it off the stock radio I don't want to mess with that yet either obviously I know the power ground where do you tie in the remote and how do you connect to the factory radio for the audio
Thanks in advance and if any one is getting rid of some gear PM me and maybe ill go that route instead
Old Mar 20, 2020 | 12:55 AM
Fireball Jack's Avatar
Fireball Jack
Amp model #? Our bikes need a class D amp.
Old Mar 20, 2020 | 01:05 AM
BluemaxRG's Avatar
BluemaxRG
I will get model as soon as I can but I must ask why a class d and what does that even mean
Old Mar 20, 2020 | 09:03 AM
marshallb's Avatar
marshallb
Most of the Pyle amp offerings are class AB which is not good in sled audio. Can't say for sure without model number though.
Old Mar 20, 2020 | 10:13 AM
Fireball Jack
Class D is a switching amp and they dont require as much power as other amps. The charging systems on our bikes is weak compared to a car.
Old Mar 20, 2020 | 10:33 AM
Fireball Jack
Here are the standard questions. Do you intend to run more than to speakers in the future? Do you care about FM? What is your budget?
Old Mar 20, 2020 | 12:18 PM
BluemaxRG's Avatar
BluemaxRG
PLMRA400 is the model number I cannot find if it’s a class D but as far as fm don’t really care about it I allways link phone and if I ever had any other speakers it would be two in the bags at most
thank you for the help btw
Old Mar 20, 2020 | 12:19 PM
BluemaxRG's Avatar
BluemaxRG
Budget for speakers I would say prob a couple hundred if that ima find a deal type of guy or barter type of dude lol
Old Mar 20, 2020 | 12:41 PM
BluemaxRG's Avatar
BluemaxRG
I also just found in my garage 4 6x9’s don’t know if they would be any good in say a saddlebag lid
I have four of these I could use
Old Mar 20, 2020 | 12:55 PM
Fireball Jack
Well you will need 1 BT355 $90.00
I run the following
Mmats 601.cx $190.00 a pair
Stinger spx700x4 $175.00
Install kit $40.00
This will be loud and clear at 80+
I think you will need to cut small holes in your speaker pods inside your fairing. No big deal and easy to do.
