Head unit speaker upgrade
Old Apr 17, 2020 | 02:07 AM
Bluesman280's Avatar
Bluesman280
Originally Posted by ECS750
So I picked up a 11 street glide for this year. Has stock audio gear on it now.(which sucks) will I get a good enough benefit from replacing head unit and speakers for this summer. I read forum after forum and see and amp is best but I don’t want to spend a ton on gear. Maybe decent new head unit and speakers in fairing to start.
Just the head unit and speakers will not be enough. It will probably sound better, but you won't have enough volume.
If I were you, I would put in a good set of speakers like the Mmats PA 601.4cx. Pair that with an amp like the Cerwin Vega B52 or if you think you might want to add additional speakers in the future, have a look at the Stinger 700 SPX.
The Stinger is radio reception friendly, not sure on the Cerwin Vega. Pick up a set of speakers adapters like the Metra 82-9601 and a line level converter like the PAC Sni 35 if only using 2 channels. You will also need an amp wiring kit.
This can be used with your factory HU until you are ready to upgrade your HU.
Old Apr 17, 2020 | 09:00 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
ECS listen to these folks and you will be much better off sound wise and budget wise.
If you want to go cheap but still get good sound you can keep your stock head unit (it's almost impossible to beat for water resistance and intuitive handlebar controls) and use a PAC line out converter. The LP7-2 is a good model in that it senses the audio being fed into it and then makes a 12v turn on lead hot. This can be used to turn on your amp. The nice thing about this method is if you get caught in a storm and want to turn off your system when you turn off your head unit the amp will power off as well. Here is a link to it:
LocPRO Series 2-Channel Line Output Converter with Remote Turn-On Circuit
They are a lot cheaper online than the price listed on PACs website. There is also a link on that page to the instruction manual for hooking it up.
For your model bike you will also need a set of 5 1/4 to 6.5 speaker adapters. They will back the speaker up enough to where you won't have to worry about the tweeter hitting the grills. Make sure you use screws large enough to hold the speaker into the adapter. I think I used #10. I believe these are the Metra rings I used:
Pair Metra 82-9600 6" to 6.5" Speaker Adapter for Harley Davidson Touring
I used a pair of Hawg Wired speaker grills because I liked the look and they are very durable. They have a sort of stock look to them. Here is a link to the set I got in case your are interested:
Hawg Wired Steel Mesh Front Speaker Grill Flat Style Harley Touring Batwing FLHT
The Cerwin Vega B52 amp has been a favorite for a lot of folks. If you think you may ever want to add lower speakers you may want to consider the Stinger SPX 700 four channel amp. It has been known to not interfere with FM reception much if that is a concern to you. You could use just two channels for now and use the other two later on if you decide to add lowers.
If anything doesn't seem clear in your mind keep the questions coming and these folks will get you straight.
Old Apr 28, 2020 | 09:59 AM
ECS750's Avatar
ECS750
Thanks for all info. I decided against the J&M and plan on doing new HU and speakers and amp. No pkgs gonna research suggestions here and go from there. 👍👍👍
HD2016110
Audio Systems
Oct 19, 2019 12:00 PM
hamp2013
Audio Systems
11
Feb 21, 2017 02:05 PM
Eric Miller 1972
Audio Systems
15
Aug 16, 2016 08:58 PM
slammed05fatty
Jul 21, 2014 11:44 AM
whynotf75
Audio Systems
18
Jun 12, 2013 09:10 PM
