Battery post distribution
Old Apr 19, 2020 | 02:49 PM
123ozzie's Avatar
123ozzie
Default Battery post distribution
Does anyone know where to get a distribution block like this that will fit on the Harley screw type battery posts?
Old Apr 19, 2020 | 02:51 PM
123ozzie's Avatar
123ozzie
If you have a link, that would be helpful! Thanks
Old Apr 19, 2020 | 05:28 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
That is a pretty tight spot on most motorcycles.
You might consider a distribution block that mounts somewhere else, or even connect the components to the starter cable terminal.
I`ve never seen a distribution block like the one you referenced that would work on our type battery terminals.
Interested in what you are connecting.
Old Apr 20, 2020 | 07:06 AM
123ozzie's Avatar
123ozzie
Thanks for the response. I'm looking to add a 4 gauge wire for an amp to the positive and negative battery posts. This option obviously won't work. I'm going to rework my question in another post.
Old Apr 22, 2020 | 01:01 AM
Bluesman280's Avatar
Bluesman280
​​​​​i use crimped on eyelets at the battery for the 4 gauge positive and negative leads. Then I run the wire under the gas tank up into the fairing to a distribution block and split off with 8 gauge to each of my amps from there.
Old Apr 22, 2020 | 09:03 AM
Tailwind's Avatar
Tailwind
Amazon = Stinger SHT204
T
Old Apr 22, 2020 | 09:23 AM
regrol1970's Avatar
regrol1970
T
It's got to be big audio for 4 gauge? That is a nice unit though.
Old Apr 22, 2020 | 11:35 AM
Bluesman280
Especially if you are running two 4 gauge cables. But I guess it starts to make sense with amps in the fairing, plus amps in the tour pack or bags. I would guess that also means multiple batteries are probably in play as well.
That is way above my pay grade, lol. ​​​​I'm just a simple 8 speaker 3 amp kind of guy.
HDSledge
Electrical/Lighting/Alarm
15
Jul 30, 2019 11:26 AM
humrider
May 19, 2019 09:54 PM
Whiskyjock
Jul 3, 2018 01:46 PM
R.N.CUMMINS
EVO
19
Mar 12, 2017 01:13 AM
SwiftyBKells
Mar 11, 2013 05:47 AM
