I finally did it...
I will update after the RF is installed.
1- bad amp
2- using LPF instead of HPF on amp
3- counterfeit amp?
4- when using DSP are the input settings correct?
5- what flash is actually on the head unit?
Most likely its a bad amp which sucks for you because it really is a great amp and it seems you paid the high price for it.
I hope the new amp works for you this time.
No, I definitely did not do this. I tried going back to AP after the highs went away and it didn't change the sound at all. Clicked back through all settings and back to HP to see if that did anything, no change.
They refunded me my money so doesn't matter now. I did buy on Amazon though, should be legit.
Yes, this problem was before, during and after the DSP was installed. I updated online then went through the setup to make sure it was set for 4 channel. I did get some differences when adjusting, just not enough to make it sound right.
RF Flash done by a Harley Dealer that is also a RF Authorized dealer. It worked great on the PBR300x2 I had on before I added rear speakers and the Stinger amp.
Thanks, I am sure it will, RF makes a good product and I am really interested to see how this works with the clipping sensor on the input and output. My buddy got a HogWorks 200W 4 speaker kit on clearance for $349 and they forgot to ship a cable so they sent cable and gave him another $100 off. So for $249 his system was sounding better than mine. I should be able to blow his handlebars off.... Hopefully this will do the trick.
Another thought I had...there is no 2ohm/4ohm switch and both speakers are 4ohm....maybe something internal was not processing that correctly. It was odd that even at low volumes with the gain very conservatively set, I was still getting distortion. The Mmats had less bass than my Boom 1 (stock) speakers. There had to be something really wrong in the system and it is unlikely that all 4 speakers would be bad from the factory.
