If i have a DSR1 that comes with the American Hard Bags flash on it to counter the Harley EQ, could i have my stock radio on my 2020 RGS flashed to this "8 speaker 2 amp (I'm assuming Rockford Fosgate flash/TechTool)", then free up the Advance EQ on my DSR1 to tune to my liking????
Yes.. But, if you have the DSR-1 file from AHB I would let it run. If you flash your head unit you will need a new DSP tune.
Juice
Thats not a problem to eq it, I just need to hook up a scope to see how flat the flash is first, then adjust to my liking for most part, right?? At the moment, Im stuck with their running file that is only set to offset Harleys extreme bass setting. I cant create anything, because that adv eq setting holds president.
or am I missing a setting somewhere that allows for AHB file and a second custom eq to be done on top of it??
