Evo X Failure
Old Nov 3, 2020 | 09:11 PM
  #51
JMC22's Avatar
JMC22
Originally Posted by marshallb
I was recently informed that the DSI-2 is discontinued!?!
Where did you hear this?
Old Nov 3, 2020 | 09:21 PM
  #52
SBates08's Avatar
SBates08
It has been discontinued.
Old Nov 4, 2020 | 12:56 PM
  #53
Babyboy's Avatar
Babyboy
This is completely true
The DD DSI-2 HAS BEEN DISCONTINUED and is out of stock. I called and confirmed this yesterday. There is a new and improved DSP possibly being released towards the the end of December.
The new DSP will have more channels and a built in bluetooth. The physical size is slightly larger than the DSI-2 but no dementions are available yet.
Old Nov 4, 2020 | 10:15 PM
  #54
Tailwind's Avatar
Tailwind
GS, I think u said u already had the ARC PSM right? Just run that sucker on the brake side and drop a cord into the brake side glove box or a windshield t-bag. It has plenty of capability for your setup. After all u did say that u were only gonna use it for bandpass right?
No need to get out over the tips of ur skis after L7 got ur stuff cleaned up a bit.
Keep it simple brother.
T
Old Nov 4, 2020 | 10:27 PM
  #55
GunslingersNation1's Avatar
GunslingersNation1
I do not have an Arc PSM, but I can get one pretty easily. My needs are very basic. With the new Neo600s in the lowers, I'm loud as ****. I just need to keep the high range out of the yellow baskets. They start to distort at higher volumes, so I'd like some more control.
Old Nov 5, 2020 | 08:08 AM
  #56
Tailwind's Avatar
Tailwind
Keep it simple brother. No need to start trying to mash a bunch of unnecessary stuff into the fairing. The ARC is a good product for what ur trying to accomplish. I used it for a while and since I now have 14 speakers to manage I had to move to more channels. That's the only reason I made the move.
T
Old Nov 5, 2020 | 09:18 AM
  #57
Hoyt 1911A1's Avatar
Hoyt 1911A1
+1 on the Arc if it has enough channels for you. I got a right angle usb micro cable so that it would lay flat against the PSM when it was plugged into it. I then coated that sucker good with silicone and let it dry so I wouldn't have to worry about it shaking loose. I then ran the other end just a little bit down the steering neck and tied it off there for easy access. I got one of those rubber USB plug caps to leave on it while it's not plugged into my PC.
So far no trouble after a year or two. When I want to make an adjustment I just pop the cap off and plug up a fifteen foot Gator brand USB extension cable to make the PC connection.
Old Nov 5, 2020 | 09:51 PM
  #58
JMC22's Avatar
JMC22
That's going to suck if it's larger than the DSI-2
Old Nov 5, 2020 | 10:17 PM
  #59
SBates08's Avatar
SBates08
It will be larger.
Old Nov 6, 2020 | 12:25 AM
  #60
Tailwind's Avatar
Tailwind
Originally Posted by SBates08
It will be larger.
Larger & more channels right? Not much larger though.
T
0maha
EVO
Apr 19, 2020 09:01 AM
Diena souper
Audio Systems
Apr 10, 2020 09:17 PM
Troy D
Canada
Feb 12, 2013 06:05 AM
JimA
Mar 11, 2012 07:38 PM
nh-dwg
EVO
Jan 19, 2012 04:31 PM
