How much "Amp" do I need?
Old Dec 17, 2020 | 12:53 PM
lefty33's Avatar
lefty33
Originally Posted by SportySmitty
To the OP, I have the Stinger and the same speakers and it sounds good. Like I said in another thread I think it sounds better than the SD 800.4 with those speakers.
Good to know Sporty. Thanks! So you're running the new GZ's & Mmats coax...correct? Do you know if yours is the older 100 w or newer 125w version?
Old Dec 18, 2020 | 02:47 PM
SportySmitty's Avatar
SportySmitty
I bought it a couple months ago so should be the new one. The box says 100W but the paperwork says 133W.
Old Dec 18, 2020 | 04:02 PM
lefty33's Avatar
lefty33
Yah...that's a newer/current one. Mine is not. Thanks Sporty!
Old Dec 18, 2020 | 04:41 PM
Bluesman280's Avatar
Bluesman280
I would order up the GZ speakers and give them a try on the Stinger, since you already have it. As others mentioned, you will be light on power for your GZ's so you won't be getting the full benefit of the upgrade. You might gain a bit lower mid-range frequencies, but I don't know how much extra volume you would gain if any.
Getting those GZs more power will help you reach the potential of your system.
You could upgrade to a bigger SD amp to run the whole system, but just bridging that Stinger and dialing it back to run the GZ's would work as well. Add in a second amp like the SD 400.4 Evox, or maybe even bridge a NVX Vadm 4 to run your tour pack speakers if you find a good deal on one of those.
Any chance you end up adding speakers to lowers or lids in the future? If so, maybe plan on an amp that will work good with any future upgrades.
Just a heads up, I think you will need a spacer ring, or an adapter like the Vtwin speaker adapters VTTP65 to get those Mmats to fit into those pods. That's what I used on my 05 Ultra.
Old Dec 18, 2020 | 04:59 PM
lefty33's Avatar
lefty33
Thanks Bluesman. I'll try the Stinger first as I have it. Not too concerned about more volume or it being louder...but if I could gain a bit lower mid-range frequencies as you say from the GZ's, that would be great! I still haven't totally "warmed" up to the Mmats in the fairing and find them a bit bright so they may do well in the TP pods. And yes, VTwin adapters are on order to fit those Mmats into the pods.
I'd prefer a single amp to run all 4 speakers and don't plan on more speakers in either the lowers or lids. As mentioned earlier, it's winter here and I have a couple of months to keep my eyes open for maybe a good used amp in the classified here and deal with it.
Old Dec 18, 2020 | 08:30 PM
Bluesman280
I haven't tried the GZ coax, but just based on Specs, I would expect a little lower frequencies than the Mmats, but even the Mmats should have been fairly warm with a bit of mid-range thump. I've never considered the Mmats bright, but I have always had a HU with a built in EQ. When guys mention their speaker sounds bright, I always question the x-over setting on the amp. Because the x-over dial is variable, too many people guess at the frequency setting, rather than trying to set it by ear. Obviously, too much bottom end will push a speaker beyond it's limits, but if x-over is set too high, things will sound bright.
I'm running 145 watts to my Mmats and x-over set that I can feel the mid-range on my chest on some songs.
The Mmats work good in the TP pods as well.
Old Dec 18, 2020 | 08:37 PM
teedoff65's Avatar
teedoff65
Agreed, If someone thinks the mmats are too bright, they have the crossovers set wrong. While they're not going to hit lower freq like other speakers, they do have some warmth. I really liked them in my last bike.
But the reviews here from guys that have tried the GZs sound good.
Old Dec 18, 2020 | 09:29 PM
Bluesman280
It's easy to miss the sweet spot on the x-over settings if a guy is just guessing based on the numbers around the dial. Just not real accurate.
I've been running my Mmats for two years, and they have always sounded good. I found them fairly full sounding and warm sounding on the Stinger. When I switched to the TX48, the Mmats were definitely not as warm. A little harsh, but not to the point of being bright, but after some fine tuning they are not bad. Definately louder with the TX48. That being said, it is time for me to start checking out other speakers. The GZ coax is on that list.
Old Dec 19, 2020 | 09:31 AM
lefty33's Avatar
lefty33
And herein lies the one negative feature of the Stinger amp. The frequency dial is so small and goes from 40 ~ 400 (in about 300ş) making it pretty tough to get them "dialed" just right. I will play with it & look for the sweet spot.
I was previously running Hertz HCX 165's in the fairing...they were warm. So yes, compared to them, I do find the Mmats brighter. Don't get me wrong, they sound good and not obnoxious bright...just not as warm as I was expecting.
Old Dec 19, 2020 | 09:47 AM
teedoff65's Avatar
teedoff65
For what its worth, here is where I had mine set on the stinger with mmats. Hope you can see it. Not the best picture. Maybe start here. That should get you in a pretty good place.
