For what its worth, here is where I had mine set on the stinger with mmats. Hope you can see it. Not the best picture. Maybe start here. That should get you in a pretty good place.
Difficult to see but they look to be just barely north of 40...at about 7:30 ~ 8:00 on the dial. Is that correct? If so, that's pretty much exactly where mine are set.
You are pretty much guessing when using just the dial. Ideally, you are better to do it by ear if you don't have a DSP, built in EQ, or anything else to verify your x-over frequency.
OK...no DSP or built in EQ (using the stock GTS hu and want to keep it that way) in play, so educate me as I'm an audio simpleton. At the advice of forum members, when tuning by ear, I've been told to set to HP filter, set my x-over first (80'ish range), then adjust the gains till a bit of distortion, then back it off a bit...which has worked in the past. So are you saying then that once the gain is set, go back and play with the frequency? Again, not an audio expert here...I know just enough to get me in trouble.
What you are doing is basically correct. But I would try it a few times, dropping your x-over a little more each time before you set your gains to compare. The trade off of lower frequencies is your gain has to be lowered. The goal is to find the sweet spot, low enough frequencies to sound good with just enough volume to enjoy it at highway cruising speeds. Unfortunately, sometimes you have to back off on the lower frequencies to get additional volume.
Hey John, one thing I'll toss out there is that a lot of what makes a speaker sound "bright" is just a characteristic of speakers when they are pushed hard. The midrange frequencies are a lot easier for our ears to pick up on at speed than lows are. I know some speakers definitely sound warmer than others, but the best cure that I know of for getting any speaker to sound the way you want it to is a DSP.
Since you probably aren't going to go over four speakers then you could do everything you need tuning wise with the little Arc PSM unit. I know a lot of folks don't want to get into the expense and complexity of a DSP but shoot swapping speakers out in hopes of getting a better sound gets expensive quick. A DSP allows you to get any speakers to sound a lot more like what you want it to.
I'd say definitely try the GZs as they seem to be well made, but if you still find things to be a little harsh or just not to your liking a DSP is something to consider. I tuned my speakers over the course of several months of riding to get the sound the way I like it now. I just left the USB cable hanging down the steering neck with a rubber cap over the plug. It's easy to plug it up and tweak the EQ settings to take out whatever frequencies are annoying me.
I've been well pleased with my Arc 600.4. On paper it definitely puts out at least 25 watts per channel more than the Stinger. I have seen some specs on the Stinger that rate it at 100 watts per channel instead of 125. The Arc is physically larger by over two inches, so I figure there is some extra copper in there somewhere.
I ain't saying the Arc is the best way to go, but I got mine used at a good deal and don't regret the purchase.
I had my system put in place by a local shop. The Arc Audio was made for motorcycles and ATVs. It's a solid choice, not the best, but you could do worse. I've got it powering AD components in the fairings and DB Drive 6x9s in the lids and it does a great job.
Hope you get things the way you like them.
Thanks for the input Bryan. Yah, 4 speakers & and an amp is my comfort zone...which I fully realize will possibly limit the ability to get the "perfect" sound. Again, I'm not complaining and saying it's bad...just thought the Mmats would sound a bit warmer. And who knows...maybe down the road I'll put a DSP in play? Good news is we have winter (which in itself really isn't good) here now and I have lots of time to deal with it.
the place that I took mine to is also an mmat dealer. They were not fans. Ive heard my AD components next to mmats and I prefer my ADs... Hertz component speakers sounded better than mmats as well
Correct Hoyt. Mine is one of the older/original Stingers that were rated at 100 x 4 @ 4 ohm. Current, newer ones are rated at 125 x 4 @ 4 ohm.
I suspect mine will be "light" so thought the Arc at 150 x 4 @ 4ohm would do a better job.
my stinger says its good for 125x4 at 4ohms but the sheet said it did 137 on channels 1&2 when they tested it at final inspection. I think if you could get as many watts as 135 to the Ground Zero youd be in a pretty good place maybe not pushing them to the max and maybe it will be a little roof on the app open time but I dont think he would be terribly light as far as the sound they produce with that kind of power. But I now have a 1200.4 in my faring because I had the same exact set up as you and I kept getting the same response that youre getting now when I asked what I should do so I bit the bullet and Im glad I did
