My '15 Limited has what was popular at the time... BT4180, 7.1s on brackets, MM651s in the rear pods, SNI-35 line out converters (NOT BT line levelers). I don't need the LL because I have the old flash... 6 speakers, 2 amps, amps off... something like that. I have working fade & everything else. I did try the BT LL but it made things worse.
My question...
Going under the fairing over the holidays to install Sirius, looking maybe for a replacement for the 7.1s. The system sounds good but to be honest I was never blown away by the 7.1s. The 651s actually sound better I think. The 7.1s seem to be "muffled" for lack of a better term.
Without going new amp, DSP etc. is there a worthwhile drop in to replace the 7.1s? Need to be at least water resistant.
Thanks!
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
