Recommended 6x9
Old Feb 14, 2021 | 07:48 PM
Aj89's Avatar
Aj89
Default Recommended 6x9
I’m getting ready to add some lid speakers and curious what’s some good 6x9 speaker for mid bass/bass
Old Feb 14, 2021 | 07:54 PM
teedoff65's Avatar
teedoff65
What's the rest of your system look like?
Old Feb 14, 2021 | 07:57 PM
Aj89's Avatar
Aj89
6.5 ground zero in fairing and 6.5 Mmats in pods
Old Feb 14, 2021 | 08:53 PM
Thatdude596's Avatar
Thatdude596
Diamond or prv 500
Old Feb 14, 2021 | 11:31 PM
travelingypsye's Avatar
travelingypsye
How much power do you have available for the 6x9's? What lid assembly are you using?
Old Feb 15, 2021 | 04:18 AM
Aj89's Avatar
Aj89
Rf lid kit and going to get a SD 1200.4 amp. Right now I have a JL 500.4 amp and a Dayton 4x8 DSP
Old Feb 15, 2021 | 08:21 AM
travelingypsye
Look into the new hertz sx 690.4 as they will mount directly to the rf lid kit, will sound damn good with the 1200.4 and are water resistant. Not the cheapest 6x9 but well worth the cost as they are purpose made for motorcycles. Mmats will need to be re drilled to fit the rf lid kit and the seal is questionable if it rains.
Old Feb 15, 2021 | 08:24 AM
teedoff65's Avatar
teedoff65
The matts will work as well. Only the mounting holes were out of alignment when I did the mmats. I also never had any leaking issues, and I was caught is a couple of HEAVY storms.
Old Feb 15, 2021 | 08:35 AM
travelingypsye
I never had a problem when I had them in my lids either but can see if not drilled properly they could leak. If you get some mmats, just be sure they are weather treated for an additional cost of $10. Best $$ you can spend.
Old Feb 15, 2021 | 11:54 AM
Aj89's Avatar
Aj89
Anybody have any input on
MS69CX – 6”X 9” 2-WAY High Output Coaxsub Speaker
