Adding 6X9s to my saddlebags
Old Mar 6, 2021 | 07:39 PM
1BRAVO9's Avatar
1BRAVO9
Default Adding 6X9s to my saddlebags
I love music, its the only reason I own a touring bike.
Until I was in my early 40s I had no desire for a "bagger", but I wanted some tunes that I didn't have to wear pods to listen to.
I also love my music loud, so when I first bought my Street Glide I upgraded the stereo, speakers, and added the amp. I bought what was generally thought of as one of the best amps for the purpose as well as the best set of fairing speakers as well.
It sounds great cruising around town and bar hopping but if I get on the interstate my sound diminishes. Therefore I was thinking of adding 6X9s in the saddlebags. Unfortunately a friend of mine stated they don't help much. I don't know, I've never driven a bagger with 6X9s in the saddlebags.
All of that being said would dual 6X9s in each saddlebag make a significant difference over single ones? I want all of the sound I can get.
What is your experience?
Old Mar 6, 2021 | 08:14 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
I can't speak for dual 6x9s, but I have one in each lid (Hogtunes lids) and with about 200 watts going to each I can hear them just fine at any speed I travel at. I did wind up having to get a DSP to get the sound I liked out of them but it was well worth it. Without the DSP they sounded a little harsh (as did the front stage to my ears). Once I was able to assign an EQ setting to the input to the amp they were on I can play them as loud as I like and hear them great without the harsh tiring sound I had. If you are running the 09 Street Glide like your sig says a lot of folks like to put speakers in the lowers to help boost their front stage. Sometimes a good beefy four channel amp for the front stage and a second amp (a lot of times a four channel bridged) for the 6x9s in the lids. I went a similar route on my Ultra and really love being in the middle of all those good tunes.
With that being said don't forget about your front stage. Do you have good enough speakers with enough watts pushing them? I ask because if your front stage is stout enough the sound will not fade regardless of speed. You may want to address the weakness up front before attacking the rear.
Old Mar 6, 2021 | 08:49 PM
1BRAVO9's Avatar
1BRAVO9
Yes, I'm good to go on the front.
Old Mar 7, 2021 | 07:17 AM
InthewindMN's Avatar
InthewindMN
What is the rest of the system?
Old Mar 7, 2021 | 08:17 AM
Thatdude596's Avatar
Thatdude596
What's your fairing speakers n amp. another option is going w 6.5 lowers. Those will be louder on the highway than bag speakers. Also look at the 8 inch lids
Old Mar 7, 2021 | 10:05 AM
eaglefan1's Avatar
eaglefan1
I hear my lids no doubt. They just aren't fill on my bike for sure.
Old Mar 7, 2021 | 08:43 PM
Hoyt 1911A1
Mentioning that the sound diminishes at highway speed is why folks asked you specifically what you had up front. If your front stage is strong enough the sound won't fade. If you don't already have speakers in the lowers that would be the best thing to add next. After the lowers tackle the lids.
Old Mar 9, 2021 | 10:27 PM
firefighter156's Avatar
firefighter156
You make a great point. What then is a simple way to address the front speakers in my 2020 Street Glide? I am open to any suggestions that won't break the bank. Don't need perfection just what's a good bang for the buck? Amp? After market speakers?
Old Mar 9, 2021 | 10:36 PM
teedoff65's Avatar
teedoff65
The new GZ's and SD800.4 evox amp is a pretty good bang for your buck combo. They're very loud and good SQ with some good bass.
I think that would run you around 700.
Old Mar 9, 2021 | 10:49 PM
Dionne Washington's Avatar
Dionne Washington
Stage III
Default Saddlebag 6x9
The question to ask yourself is what type of sound are you looking for??? What type of music do you play? Rock, Rap, R&B etc...Do you want deep bass? clear high frequencies? or high output in general.
Adding 6x9s in the bag is definitely a foundation to a better quality system. The more speakers you add the better it will sound specially if you only have 2 at the moment.
I recommend adding 6x9s (Hertz, Diamond,Beyma) in the lids and adding 8" (Hertz, PRV, Ground Zero) mid bass inside each bag > two 6x9s in each bag if your goal is to gain higher output and deep bass.
