HD Audio by Rockford Fosgate Stage II Install Issue
Old Apr 24, 2021 | 07:13 AM
Ccraze's Avatar
Ccraze
Default HD Audio by Rockford Fosgate Stage II Install Issue
Just installed the new HD audio by RF Stage II fairing speakers and amp in 2021 RGS using supplied install kits. Instructions are terrible and can only find 1 install video (by RF) that is minimally detailed at best. Problem is I get no sound out of the speakers. Tried to do setup using the HD audio app but get no White noise. I checked the connections and all seem okay. Is there any way to tell if amp is getting power? Not sure what else to trouble shoot. Tried reseating the connections, checking the canbus connections in brake side cover, reseating the 40 amp fuse and Re plugging the speakers. Nothing seems to work. Also, I pluged the speakers into the original connections (bypassing the amp), I get sound. Any ideas?
Old Jul 4, 2021 | 03:25 PM
LouisGelinas's Avatar
LouisGelinas
Stage III
Default Solution
[QUOTE=Ccraze;19885249]Just installed the new HD audio by RF Stage II fairing speakers and amp in 2021 RGS using supplied install kits. Instructions are terrible and can only find 1 install video (by RF) that is minimally detailed at best. Problem is I get no sound out of the speakers. Tried to do setup using the HD audio app but get no White noise. I checked the connections and all seem okay. Is there any way to tell if amp is getting power? Not sure what else to trouble shoot. Tried reseating the connections, checking the canbus connections in brake side cover, reseating the 40 amp fuse and Re plugging the speakers. Nothing seems to work. Also, I pluged the speakers into the original connections (bypassing the amp), I get sound. Any ideas?[/QUOT
Did you find any solution?
Old Jul 4, 2021 | 04:09 PM
Hammz's Avatar
Hammz
The instructions are pretty complete. Did you purchase all the parts needed?
File Type: pdf
Old Jul 4, 2021 | 04:33 PM
Hammz's Avatar
Hammz
Default RF Install Article
Here's an article w/pics that I did a few months ago.
File Type: pdf
Old Jul 4, 2021 | 06:30 PM
LouisGelinas
Stage III
Yes I did, but I'm not sure inside the service cover, I have a RGS 2021 and the instructions are not very clear... in my opinion.
I bought the stage 2 with just two front speakers.
Old Jul 4, 2021 | 07:09 PM
Ccraze's Avatar
Ccraze
[QUOTE=LouisGelinas;20033753]Yes I did, but I'm not sure inside the service cover, I have a RGS 2021 and the instructions are not very clear... in my opinion.
I bought the stage 2 with just two front speakers.[/QUOTE
i ended up getting to work. Had to take to dealer for the flash even though corporate said it didn’t need the flash.
Old Jul 4, 2021 | 07:32 PM
LouisGelinas
Stage III
Thanks, will do that.
Old Jan 19, 2024 | 08:35 AM
1JLGriffith's Avatar
1JLGriffith
Stage I
Default Install issue with Rockford fosgate Harley system
I would recommend going to Law Abiding Biker and purchasing his install video for your bike and system. They saved me so much time and I agree, the Harley instructions are the worst, meant to make you go to the dealer to install their system.
Old Aug 4, 2024 | 10:13 AM
TrB72's Avatar
TrB72
I’m pretty sure you have to flash the radio, either take it to the dealer or buy the flash kit? I would check the Law Abiding video.
Beantowntat
Audio Systems
Jul 26, 2020 06:35 PM
peramus
Audio Systems
Oct 24, 2018 01:53 PM
tuleyne
2014-2024 Touring Models
Sep 29, 2015 11:33 PM
Second Wind
Audio Systems
Sep 5, 2015 06:57 AM
AZ-Breakout
Audio Systems
Mar 4, 2015 11:01 AM
