Here we go
Old Apr 24, 2021 | 07:29 PM
Chris Mancini's Avatar
Chris Mancini
Default Here we go
Ok so I have hertz sv165 and st25 in fairing hertz sx690 in lids sd evox 800.4 amp and dsp. Has been working fine all of a sudden today was riding to work about 45 mins and starts cracking and than cut in and out took fairing off and didn’t see anything wrong except ground screw in amp was slightly loos fixed that and let play for a bit than cut out again almost all sound for about 20 mins or so put back together started bike to leave work this evening no sound than all of a sudden as I’m leaving starts working again get more than 1/2 way home does same thing with cutting in and out tried to keep it going until I got home but of course started working fine again. Let play for about 20 mins in garage and starts lightly fading in and out. I’m at a loss here.
Old Apr 24, 2021 | 08:50 PM
Tailwind's Avatar
Tailwind
Check power and ground at the battery.
T
Old Apr 24, 2021 | 09:03 PM
Chris Mancini
T
got a few little turns out of them but not loose loose. Would dsp cause this issue?
Old Apr 24, 2021 | 09:32 PM
Thatdude596's Avatar
Thatdude596
Gain set too high?
Battery connections tight
All connections tight
Look at the lugs on the evox amp. Mine did exact same thing terminal plate was replaced under warranty
Old Apr 24, 2021 | 09:38 PM
Chris Mancini
Originally Posted by Thatdude596
Gain set too high?
tightened connections a little at battery but weren’t loose loose. Lugs are tight no movement on board gains are where they’ve been set for a while don’t know why gains would be issue now. It started getting low and than back to high in garage earlier at lower than I normally play volume. Was told amp sounds like going into protection mode but can’t find anything loose loose
Old Apr 24, 2021 | 10:36 PM
Tailwind's Avatar
Tailwind
I hate to say it but the SD quality control is garbage so if u triple checked all connections and gains it very likely that the amp is the issue.
Don't get me wrong, I run all SD amp due to the raw power in a small footprint but about 1/3 of the ones I have purchased were a do-over.
Their warranty is great, just not the initial quality control.
T
Old Apr 25, 2021 | 12:13 AM
Thatdude596
Everyday someone is getting a doa evox or someone is sending one back. Pretty alarming in my opinion
Old Apr 25, 2021 | 05:39 AM
Dsm Limited's Avatar
Dsm Limited
Old Apr 25, 2021 | 11:05 AM
Chris Mancini
Originally Posted by Dsm Limited
found loose wire at ring terminal on negative battery side. Ride for an hr no issue. Hope that’s all it was.
highwayman50
Audio Systems
Nov 26, 2020 12:05 PM
Houston_t
Audio Systems
16
Apr 26, 2017 05:41 AM
matt76cmich
Audio Systems
32
Feb 19, 2016 09:22 PM
Molarman
Audio Systems
13
Mar 25, 2013 09:25 PM
Texas Rapier
Aug 27, 2010 01:06 PM
