SD 1200.4 amp on SGS
Old Jun 16, 2021 | 07:48 PM
252SGS's Avatar
252SGS
Default SD 1200.4 amp on SGS
Looking for ideas on the best way to mount a SD 1200.4 in the front fairing of a 2015 SGS. I searched the web and tried the recommended 1x6 pvc board. This will not work, bc it will not allow me to attach the front fairing. The amp rides too high for the fairing. I've installed the new speakers and ready to button this last piece up.. Thanks
Old Jun 16, 2021 | 07:59 PM
mcdc1224's Avatar
mcdc1224
I use small nylon bushings or brass
Old Jun 16, 2021 | 08:17 PM
252SGS's Avatar
252SGS
I have bushings. The issue is only 1 hole from the amp will line up in the fairing to mount it. I'm sure I'm missing the obvious answer. I just don't see it. My RF had an amp bracket which made it easy.
Old Jun 16, 2021 | 08:32 PM
SBates08's Avatar
SBates08
You really need nothing more than some of the 3M Velcro to secure the amp.
Old Jun 16, 2021 | 08:36 PM
252SGS's Avatar
252SGS
Didn't think of that. Thanks
Old Jun 16, 2021 | 08:48 PM
SBates08's Avatar
SBates08
You know the type I'm referring to? Takes a flat head screwdriver to get that **** apart.
Old Jun 16, 2021 | 08:53 PM
hamah's Avatar
hamah
Did you mean
Velcro ALFA-LOK Velcro ALFA-LOK
? Alternatively, there is
3M Dual Lock 3M Dual Lock
, or the consumer version which is called
Scotch Extreme Scotch Extreme
(and can be found in smaller quantities). I've not tried ALFA-LOC but the 3M **** is really ****ing strong
Old Jun 16, 2021 | 08:55 PM
252SGS's Avatar
252SGS
Ok. I will try that. Thanks for the info.
Old Jun 16, 2021 | 10:32 PM
SBates08's Avatar
SBates08
Originally Posted by hamah
Did you mean
The 3M dual lock scotch extreme. Comes in black or white.
Old Jun 17, 2021 | 12:03 AM
travelingypsye's Avatar
travelingypsye
Just make sure you dont cover the fan with it.
