Loose audio volume button
Old Jul 5, 2021 | 10:40 PM
Weeboy1's Avatar
Weeboy1
Default Loose audio volume button
Posted in the General section but maybe get more feedback here.
Just wondering if there’s a way to tighten up the volume switch on my handle bar control? Or if it can be removed and replaced? Works fine but it’s wiggly like a child’s loose baby tooth. Worried it’s just gonna eventually fall off. Don’t want to open up the handlebar control if there isn’t a fix for it.
any thoughts?
2010 ultra
Old Jul 5, 2021 | 11:50 PM
smittyrock3's Avatar
smittyrock3
Just got rid of an 09 Ultra and I was having the same problem. The button flew off on the highway when I was adjusting the volume and all that was left was a little metal stud. The cruise control was loose at one point and I had it replaced under the extended service plan. The can be replaced but I don't think they can be tightened.
Old Jul 6, 2021 | 07:05 AM
Weeboy1's Avatar
Weeboy1
Thanks, yeah did a bit more research and found instructions for the replacement of the switch caps. Shows using a specific tapered fork like tool to get between housing and cap and separate the two. Not sure how cap is fixed to stem and tried pushing it in to better seat it but made no difference. It still functions fine so gonna leave for now and may replace with chrome.
thanks for the input
Old Jul 6, 2021 | 08:28 AM
SBates08's Avatar
SBates08
Those caps are basically a tight slip fit over the stem. The new caps sometimes need a little reaming out to get them to fit the stem and if you push inward on that stem very hard the switch will break. Get your replacement cap, ream it out just enough that it takes a bit of pressure to slide it on the stem and add a dab of blue loctite inside the hole before you seat it on the stem.
Old Jul 6, 2021 | 10:13 AM
Weeboy1's Avatar
Weeboy1
Thanks Shannon, appreciated.
Ride safe
Weeboy1
General Topics/Tech Tips
Jul 10, 2021 09:08 PM
GARY DYER
Audio Systems
Mar 5, 2021 03:27 PM
Edward Brown
Electrical/Lighting/Alarm
Jan 27, 2016 06:02 PM
bigpappa160
EVO
Dec 4, 2015 10:30 PM
Notgrownup
Audio Systems
Mar 16, 2014 09:31 AM
