WIM and Wireless Headset Issues.
Old Aug 31, 2021 | 10:41 AM
Road Glide Rob's Avatar
Road Glide Rob
I possibly have the same problem.
New to me a 2019 CVO Road Glide in pepper red.
My old Sena 20S (firmware v2.0.5) worked on the RG as it should, music coming through the bike’s speakers, sat nav prompts form the headset.
So I decided to up-grade to the Sena 50R (firmware v1.0.9), then no sat nav prompts from the headset, further research I found that the 50R is not fully compatible with the Boom, (mono sound only).
OK now I’ve bought a HD Sena 30K (firmware v3.1) and still no sat nav prompts from the headset.
Not sure of the firmware on the WHIM but will check soon.
I do not have any earlier firmware for the HD Sena 30K to see if that will resolve the problem
Old Aug 31, 2021 | 11:13 AM
smitty901's Avatar
smitty901
Originally Posted by HFS
Interesting @netmeister
I bought the 2020 FLHTKSE. It came with a WHIM, 30K Harley-Davidson SENA, and it is less than satisfactory performance.
A buddy asked me which one to buy - I said the 30K Harley-Davidson one. He did. Our communications are NOT clear and I can not audio Multitask. Another friend also has the HD WHIM & 30K. Same story. Went with my wife for a ride, each different motorcycles, she has the 20S. Communication clarity diminishes over time, requiring a power-down reset on one, or both units... I can't initiate or close intercom, only she can, which I'm sure doen't bother her...
--Funny thing - I had a 2017 FLHXSE, considered the GTS to replace the GT. It didn't come with a WHIM... According to HD, the WHIM isn't cross-compatible, however, @Circa58 indicated their older WHIM worked with both the GT and GTS... I don't even use CarPlay much anyhow. I was trying to update everything to ensure a firmware wasn't to blame, GTS, WHIM, and 30K. All that was in _need_ of an update was the Dealer Database... ha ha. My T-shirt drawer is full thanks...
All this **** is buggy.
H
My WHIM was on the 2017 among the first that HD sold . It was reinstalled in my 2020 and works just fine. The WHIM firmware is thy same one that has been out for a long time. It has only been updated twice. I would bet OP problem is the sound is turned off od win in setting some where.
Just a side not even my Old Cardo Q3's still work with the WHIM on the 2020. tried it just for the heck of it.
So HD telling you a WHIM off a 2017 is Not compatible . He is not being truthful. Check the part numbers same unit from day one to 2021.
https://www.harley-davidson.com/us/e...ule/p/76000768
Old Aug 31, 2021 | 12:29 PM
chiefmmck's Avatar
chiefmmck
Mine is essentially the same problem. I have two 30Ks; one works as it should, the other pairs to the WHIM, but is basically dead to the WHIM...no functionality. As a stand-alone 30K, it can intercom to the other headset via the 30K controls and will play music via bluetooth to a smartphone. Both headsets running firmware 3.1 and WHIM 1.1.14.
Old Aug 31, 2021 | 01:12 PM
chiefmmck's Avatar
chiefmmck
Additional info, my dealer just pulled a 30K off the shelf, paired it to one of their bikes and it doesn't work either. Same problem as the bad one I have. Pairs to WHIM, announces Boom Audio Connected, but no headset functionality via the GTS.
Old Aug 31, 2021 | 03:46 PM
chiefmmck's Avatar
chiefmmck
My dealer confirmed that this is a known 30K problem and Harley is working it. Of course, no timeframe to resolve known yet.
Old Sep 1, 2021 | 10:39 AM
Road Glide Rob
Default Sena 50R working
Update:
I've just updated the WHIM frimware, from v1.0.2 to v1.1.14
and have tested the Sena 50R which now works OK, (music from bike speakers, sat nav prompts from headset).
Have yet to test the HD Sena 30K.
Old Oct 18, 2021 | 12:11 PM
netmeister's Avatar
netmeister
UPDate. Got text from factory guy. New headset firmware... 3.2 Fixes the problem.
Old Oct 18, 2021 | 05:23 PM
cycle7447's Avatar
cycle7447
Community Influencer
Thanks for all of your hard work
Old Oct 23, 2021 | 06:51 PM
UltraV's Avatar
UltraV
I have a 2016 TriGlide. I installed the WHIM wireless headset module. My wife and I have identical Sena 50 headsets. They seem to work perfectly on the bike except that she can’t hear me at speeds over 40 mph. I can hear her perfectly at any speed. We have adjusted all the settings on the bike, and the settings are not the problem. People can hear me just fine on my headset when they call me on the bike or I’m on the CB, so I know my mic works. We have iPhones.
Anyone have any suggestions on how to make it so my wife can hear me on the intercom? I would prefer not to have to buy the inferior HD headsets.
Old Jan 6, 2022 | 05:31 PM
rfhennessy's Avatar
rfhennessy
Stage I
Got a new 2021 Ultra Peace Office Blue. Bought a bunch of stuff on line from https://shop.newcastlehd.com/. You get quite a discount but they don't cut you any slack on the shipping cost. Anyway bought a WIM (and CB) and installed same. I bought a couple of after market wireless heasets (Fodsport M1). Could not get headset to reliably pair as rider. Had no problem pairing as passenger. Trip to dealer and after replacing WIM everything paired for the most part. The aftermarket headset sound was tinny and no stereo. I knew about the stereo issue as that is by design. There are some quirks when the bike is shut off and restarted, the headset does not re-connect reliably. Once I figured that out I just have the bike FORGET the pairing before I turn the bike off and once the bike is restarted I repair the headset. But other than that and the lack of stereo everything works fine. Harley wants you to by their $300.00 headset not an $80.00 after market headset. Harley OEM's the Sena headset from SENA and they are nice.
I broke down and purchased one Harley heaset (30K) to give it a try. The new headset pairs and reconnects flawlessly. Only problem is I get no bike audio through the earpiece. Earpiece talks to me during power up and configuration changes and I can tune to FM station and hear fine. I can pair headset to phone and the sound quality is excellent. Any audio that originates from the bike does not come through the earpiece. (yes I have the audio redirected).
Since the WIM comes as standard on a CVO I visited several dealers and because of my good looks, easy going demeanor ( when that did not work I tried wining) I was able to try to see if I could get my headset working on some floor bikes. Headset failed on these test bikes as good as it failed on mine. I did find one dealer that had a headset in inventory and was able to try that headset on my bike and it did not work either. (hmmmm).
All this time I had an incident opened with Harley and did receive several phone calls and went over several configuration setting and nothing we did improved the situation. Several times I had to fend off the claim it must be a problem with my installation. I countered such a claim with it works with my after market, cheap headset.
Anyway because of my superior troubleshooting skills (retired IBM programmer) and intellect I warranted a visit from the factory guy. I met him at the dealer and he brought his own headset. His worked fine on my bike and mine failed to work on his. (at last progress). We got a new headset out of dealer inventory and it failed in the same way as mine had. I told the factory guy that I believed that Harley had a comparability issue that they did not know about as was sure they would fix it. The factory guy took my headset and the one from dealer inventory back to the ranch. They agreed to replace my headset and again because of my good looks and easy going personality agreed to include a second unit as compensation for all the aggravation and effort I put in trying to troubleshoot the problem. Picked up my new toys this week and could not wait to try them out. I told the service manager (who I had become quite friendly with ) that I give him long odds that one or both of the replacement headset would not work. Should have taken that bet. I got home and my new, direct from the factory, units failed in the same way as my original headset and the one that was pulled out of dealer inventory.
I did have the forethought to get the factory guys phone number and left him a message and advised him that we now had four (4) units all exhibiting the same problem. I got a text a little later indicating that they were going to have a meeting about my bad luck and that is where we are at this moment in time.
Hey, I'm new to HD Forums. I have the exact same problem on my 2021 Ultra Ltd. CVO. Have HD rectified the issue?
