Just checking - your Sena 50s Harley should work OK with Carplay. Ss far as connecting with Cardo, the folks with the Cardo system can use mesh to link you in.
There is a work around, a plug, but this does not work with the CVO. You can try the new dongle from J&M - that worked with my Cardo, In case you have a CB, you will not be able to connect - but, it seems that all else works well.
Yeah, the Sena works fine with CarPlay on the bike, I would just like to have comms with those that use Cardo when I ride with them. Mine is a CVO but I don't have a CB so I will go down the rabbit hole of this dongle you speak of and see what that yields. I understand why companies do proprietary builds - because they think their product is better or perhaps technology evolved and something better came along. It seems to me that both companies would benefit from a shared collaboration to make their products work together though. Thanks for helping... I will look into this.
