Amp turn on delay
Old Sep 13, 2021 | 05:01 PM
rsking45's Avatar
rsking45
Default Amp turn on delay
Is there a way to delay when the amp turns on. 2015 SGS with stock head unit w/ R F flash, SD 800.4 GZ yellow baskets.
Issue I'm having is, when I turn ignition on and HU is powering up, I get two loud blipping noise from left speaker then right speaker, and then left speaker and right speaker again. Doesn't matter if volume is all the way down or volume up. I always turn the volume down before turning bike off. I'm getting the 12v amp turn on from a 12v accessory wire upper right side under fairing. Power and Ground coming from battery.
Thanks all
Old Sep 13, 2021 | 06:17 PM
lefty33's Avatar
lefty33
I could be wrong but I believe a PAC TR4 could be wired in for that. I had one wired in my previous 2012 UC for a 1 second delay because of a start-up pop I was having.
I don't have enough experience to know if the newer CAN BUS system in the 2014+ bikes works different than the earlier bikes or not?
Ask some more questions and check it out for yourself at...https://catalog.pac-audio.com/catalo...lty-items/tr-4
Old Sep 13, 2021 | 08:20 PM
Dsm Limited's Avatar
Dsm Limited
If you have a dsp, it can delay. No dsp, the TR4 does the trick
Old Sep 14, 2021 | 07:34 AM
SBates08's Avatar
SBates08
Not necessarily. All DSP's aren't created equally. There are some that do not have the ability to delay turn on.
Old Sep 15, 2021 | 04:44 AM
Dsm Limited
You are correct!!
A guy gets so use to using what he bought, you forget there's other stuff out there...🙂🙂
Old Sep 15, 2021 | 07:21 AM
chopper_man's Avatar
chopper_man
Use an inline time delay relay. Short $.
Amazon Amazon
Old Sep 16, 2021 | 12:48 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
The PAC TR4 is what I would try because it could be triggered from an unused factory speaker wire. That way if the head unit is turned off the amp turns off as well. Sort of creates an amp turn on lead that the factory head units don't have.
Old Sep 22, 2021 | 11:44 PM
rsking45's Avatar
rsking45
I bought the Pac TR4 and I’m not sure wher the green low voltage wire gets connected to. The directions states to use a speaker wire. Does it have to be a unused speaker wire, or Can I tap into one of the fairing speakers wires?
Old Sep 23, 2021 | 08:37 AM
Circa58's Avatar
Circa58
I ran the accessory power on the front right fairing.... to the DSP408 remote in, and then the DSP remote Out to theSD1200/4 amp's remote in
Old Sep 23, 2021 | 08:43 AM
lefty33's Avatar
lefty33
When I used one, I went per instructions. Put a spade connector on it and plugged into one of the stock (unused) speaker wires...easy.
