Fairing Speakers
Old Oct 2, 2021 | 03:12 PM
LN Nation's Avatar
LN Nation
Default Fairing Speakers
So, I’ve had these Mmats PA601.4 coaxial speakers in the fairing of my 2021 Road Glide for a few days and they are just a bit bright for my liking. They are really efficient and my SounDigital 800.4 amp really powers them well at 150 watts per channel. I just preferred the warm sound of the H.A.T. Unitity speakers that I had previously although they were noticeably less efficient.
Looking for advice on a warmer sounding, efficient 6.5” coaxial speaker. I don’t feel like rolling the dice again on my third set. I’ve seen that a lot of people are using the Yellow Baskets and the Hertz Neo speakers. Would either of there fit the bill or should I consider something else? Thanks.
Old Oct 2, 2021 | 05:29 PM
Dsm Limited's Avatar
Dsm Limited
Do you have a dsp in play? If not, take those Mmats down to about 110-120 watts and the hpf to 90hz. Let us know what you think!
Old Oct 2, 2021 | 07:04 PM
slodsm's Avatar
slodsm
Like DSM said, tuning.
Mmats would be the last speaker on earth I called bright. I’ve ran them harder than 150/channel in a Jeep but I used a DSP to tone them down a bit up top when you really pour the power to them.
Very nice speaker and will take some abuse but they do need some tuning or less power.
Old Oct 2, 2021 | 07:28 PM
LN Nation's Avatar
LN Nation
It’s likely that I won’t have a dsp installed but I’m currently using the Kicker flash, which has a slight boost in the low end.
Old Oct 2, 2021 | 07:48 PM
teedoff65's Avatar
teedoff65
Still, take the watts down and lower the HP like DSM said. I ran these for over a year in my last bike and to me the are not that bright at all.
Old Oct 2, 2021 | 09:02 PM
cshocker's Avatar
cshocker
It’s going to be tough to get the same warmth as your HAT’s from a pro audio coax. That’s the design of them: to be loud.
Old Oct 6, 2021 | 12:40 PM
LN Nation's Avatar
LN Nation
Just a quick update. I brought down the amp's output to 20v per channel. In theory, this is 100 watts per channel which is well below the rated output of the amp and the rating of the speakers. I also set the HPF at 80 hz on the amp. These two adjustments resulted in a much more pleasing sound. In retrospect, my initial goal was just louder audio than the stock system without breaking the bank, Mission accomplished (although, I did add lid speakers which weren't part of the original plan.) Thanks to those that responded.
Old Oct 6, 2021 | 05:05 PM
Dsm Limited
I'm glad it worked out for you!! Thank you for the update. It's nice to know the end result.
Old Oct 6, 2021 | 07:02 PM
teedoff65's Avatar
teedoff65
Now you might can bump up the watts a bit but also move the HP up a bit as well. Still have some warmth, but get a little more sound...if you need it. Even at 100 watts, they probably get plenty loud enough.
As said, always good to hear results from questions asked here.
Old Oct 13, 2021 | 09:37 AM
Lethal Weapon's Avatar
Lethal Weapon
forbidden
Audio Systems
31
May 26, 2021 08:27 AM
Eric Steward
Audio Systems
Sep 22, 2019 08:09 PM
WingMan12
Audio Systems
Jan 15, 2013 08:47 PM
Str33tgl1de
Jun 7, 2012 06:54 PM
blown alcohol
Sep 23, 2009 03:09 PM
