8 or 4 AWG wire from battery
Old Aug 21, 2022 | 10:07 AM
neonflx's Avatar
neonflx
Default 8 or 4 AWG wire from battery
I'm adding / relocating my amp's to inside the fearing and would like to know if 8 AWG is ok or do I need 4 AWG from the battery.
My current setup is a BT4250 running Hertz SPL SHow with DA Horns (front) and GZ yellow basket 7x10 on saddle bags lids this amp is inside the fearing, SD 800.1 inside saddle bag running 2 DA MSPRO8.
on this setup I have an 8 AWG from the battery running to the BT4250 and another to the SD 800.1
My new setup will be as follow
BT4250 running the SPL and GZ
DA Micro2v2 running the DA Horns
SD 800.1 running MSPRO8
Dayton 408 DSP
Would like to keep the current 8 AWG which has a 40 AMP fuse, run it into a fused distribution block in the fearing (with 40 AMP fuses as well) and from there provide power to the 3 amp's inside
Would the 8 AWG be able to handle the load or to play it safe should I use 4 AWG from the battery to the distribution block instead?
TIA
Old Aug 21, 2022 | 02:29 PM
Dsm Limited's Avatar
Dsm Limited
8g wire to supply all 3 amps? I wouldn't try it. Definitely 4g to distro block and 8g out
Old Aug 23, 2022 | 09:47 AM
neonflx's Avatar
neonflx
Thanks, makes sense, appreciate the feedback
Old Aug 23, 2022 | 09:57 AM
cshocker's Avatar
cshocker
To run 3 amps that require 8G, I would do a 4G run to distribution block and then another 8G run from battery to amp
Wolfmiester
Audio Systems
78
Jul 23, 2021 01:14 PM
coolbikeguy
Audio Systems
Jun 27, 2020 10:17 PM
Pologreen
Audio Systems
Jun 30, 2017 05:09 PM
SgtMic
Audio Systems
Feb 10, 2017 06:26 PM
Rick Tessandori
Jul 16, 2016 08:54 AM
