2 speaker and amp recommendation
Old Aug 31, 2022 | 10:14 AM
Jetblack3's Avatar
Jetblack3
Default 2 speaker and amp recommendation
Looking to offer a little guidance for a co-workers audio system upgrade. 2013 street glide, already has aftermarket head unit. Looking to upgrade the 2 factory speakers to 6.5 inch and an amp. Don't care about FM reception / $500ish budget
Old Aug 31, 2022 | 10:36 AM
jory434's Avatar
jory434
I just did a pair of MMAT 601cx's and a NVX VADM2 amp in a friends bike. Thats my 2 cents.
Speakers - $250
Speaker adapters - $20
Amp - $180
RCA cables - $10
Amp install kit - $20
Old Aug 31, 2022 | 10:41 AM
Fireball Jack's Avatar
Fireball Jack
Mmats PA601.4cx and SS PN2.350D
Old Aug 31, 2022 | 10:44 AM
Fireball Jack
Speakers - $250
Amp - $180
RCA cables - $10
I always forget about the NVX amps and I had one. They run a bit hot but are a good budget amp.
Old Aug 31, 2022 | 11:18 AM
jory434's Avatar
jory434
The JL 280/4 bridged would be my first choice, but doesnt fit this budget.
Old Aug 31, 2022 | 11:38 AM
cshocker's Avatar
cshocker
There's one in the classifieds. It's older, but they are same as the new ones.
OP, mmats pa601cx's and a JL MX280/4 is one of favorite budget setups.
Old Aug 31, 2022 | 11:46 AM
JAGlide's Avatar
JAGlide
Speakers - $250
Amp - $180
RCA cables - $10
^^^^ This
You can also look at the Ground Zero 6.5" Coax GZCF 6.5SPL ($300) speakers and the NVX VADM4 400W ($180) . SounDigital EVOX 400.4 - 4Ω ($220) or SounDigital EVOX2 400.4 - 4Ω ($250) amp is another amp possibility. Mix and match any of these and be within or just over your budget.
Old Jan 1, 2023 | 07:02 PM
68_340_Cuda's Avatar
68_340_Cuda
Do you know if that amp would work well with the MMATs 601cx in a 2020RGS without flashing the radio?
Old Jan 1, 2023 | 07:29 PM
cshocker's Avatar
cshocker
No amp will work well without a flash.
Old Jan 13, 2023 | 10:10 AM
aaazdaddy's Avatar
aaazdaddy
Default Flash
Do I need a flash even with just an amp with the two front speakers?
I'm running a Rockford Fosgate Amp(a mediocre amp, but came about it free, so I'll give it a try). Considering the MMATS, either the LS65cx (which should fit without a mod) or the PA601.cx (which will only fit with a little mod with a heat gun).
Bob
