Tweeters buzzing
Old Nov 9, 2022 | 03:46 PM
Harley1004's Avatar
Harley1004
Default Tweeters buzzing
On my 2008 electric glide, I have installed a diamond 600 W amplifier, aquatics stereo, 4- 6 1/2”
speakers, And two tweeters where the oil pressure gauge and ambient temperature gauge used to be.
Key on, engine off, no music playing from the stereo to speakers, I get a annoying buzzing sound through the tweeters until I pull the brake. Then it stops. Everything is quiet like it should be.
I would appreciate it if one of you could steer me in the right direction
Old Nov 9, 2022 | 07:22 PM
Babyboy's Avatar
Babyboy
Were is the remote turn on wire from the amp wired in for power?? Is there 12 plus volts going to the remote turn on wire without
activating the brake light circuit?
Were is the remote input switch set at?
If the problem still exists start checking
suggestions below.
It sounds like a poor connection either on the power supply side of the amp or a ground loop issue possibly caused by a faulty RCA cable.
If you still can't find the issue causing the noise maybe post your location and MAYBE there is a forum member close to you that may be available to swing by and give you a hand
Old Nov 9, 2022 | 08:30 PM
Roadking69's Avatar
Roadking69
Floor noise the horns are very efficient it’s a trade off on setting gains
Old Nov 10, 2022 | 12:25 AM
hamah's Avatar
hamah
and the noise goes away when the brake switch is activated because?...
Old Nov 10, 2022 | 01:56 AM
Harley1004's Avatar
Harley1004
suggestions below.
I will try these things that you have suggested. When I get through troubleshooting I will come back and post to my findings. Thanks for the input
Old Jan 8, 2023 | 04:43 PM
Harley1004's Avatar
Harley1004
It was the brake light, turn signal, stoplight, and module. End post.
Tupp
Audio Systems
23
Jul 4, 2022 11:20 AM
Front Sight
Audio Systems
Jun 6, 2021 08:38 AM
Loujr28
Jul 22, 2019 10:28 PM
Autotec
Audio Systems
25
Apr 18, 2016 09:39 AM
freebooter
Audio Systems
Mar 22, 2014 12:45 PM
