White noise / static
Old Jun 5, 2021 | 02:51 PM
Front Sight's Avatar
Front Sight
Default White noise / static
I made some upgrades to my system and I am now having an issue with white noise / static. Replaced the stock head unit on my 2013 Street Glide with a Kenwood KMR-M328 BT, Infinity speakers to a set of Mmats, used all Metra install parts and interface and reused a B52 amp. Everything works as it should but now I have static coming through regardless of the source (radio or Bluetooth). Amp is grounded to the battery and velcro to the top of the head unit. Checked all connections and can’t find anything loose. Help!
Old Jun 5, 2021 | 04:36 PM
bradsULtd's Avatar
bradsULtd
Try running a ground wire or strap right to the frame, close to the amp...what gauge is the ground wire going back to the battery? Its probably acting like a high impedance, picking up electrical noise and injecting it right into the amp...
Old Jun 5, 2021 | 06:04 PM
Front Sight
Running 10 gauge for power and ground.
Old Jun 5, 2021 | 06:44 PM
madhunter60's Avatar
madhunter60
Did you check the new headunit for clean signal/volume level and then reset the gains to the new headunit?
Old Jun 5, 2021 | 06:46 PM
Front Sight
Yes. Everything is flat.
Old Jun 5, 2021 | 07:02 PM
Tailwind's Avatar
Tailwind
Gains to high?
T
Old Jun 5, 2021 | 07:05 PM
Front Sight
Lowered the gains and it made no difference.
Old Jun 5, 2021 | 10:39 PM
Front Sight
Well, I appreciate all the input, but the truth is I am an idiot. I left the line output converter in place from the stock head unit and that was causing the static. Removed it and all is good. Feel free to roast me!
Old Jun 6, 2021 | 07:52 AM
mcdc1224's Avatar
mcdc1224
We have all been there.....if we were honest
Old Jun 6, 2021 | 08:38 AM
decencyxdefied's Avatar
decencyxdefied
No need to roast ya. I've made more mistakes with audio than I care to share on here. the best part about this tho is Someone else will have the same issue and will learn from your thread.
Seung Ha
Audio Systems
Feb 7, 2020 02:00 PM
Genius
Audio Systems
Jan 15, 2020 05:53 PM
DoubleD8
Audio Systems
Oct 14, 2019 05:31 AM
BlessedHellride
Audio Systems
Mar 22, 2014 08:19 AM
customsoftail200
Audio Systems
Mar 7, 2013 09:13 PM
