Troubleshooting audio system
Old Jan 27, 2023 | 12:27 PM
BilltheBee's Avatar
BilltheBee
Stage III
Default Troubleshooting audio system
I am trying to determine where and when I should have have voltage at the speakers and the speaker switch on the control panel of my ‘09 Ultra.
I need a printable diagram or something to reference.
The radio was intermittent, I could toggle the switch and it would work for a bit and then drop out again…now I got nothing. I have voltage at the switch but not sure it is where it should be when toggling.
Should I have continuity between the switch and the speakers?
Help! Thanks in advance.
Old Jan 28, 2023 | 09:52 AM
Budda109's Avatar
Budda109
When you have nothing is the radio lit but no sound? Or it is dark as night?
Old Jan 28, 2023 | 10:09 AM
BilltheBee's Avatar
BilltheBee
Stage III
The radio is lit & I am getting the indicators in the lower right corner when I toggle.
Old Jan 28, 2023 | 02:03 PM
Budda109's Avatar
Budda109
Default Bad head unit
Going to say you have a bad head unit. Not that uncommon. But here is the schematics.
Old Jan 29, 2023 | 10:03 PM
Babyboy's Avatar
Babyboy
Just an FYI when checking voltage at the speakers and switches the signal is
AC VOLTAGE.. going to the speakers.
When diagnosing the output of the system use a steady 1k hz test tone so there is little to no variation
edjhover1
Audio Systems
Sep 2, 2019 01:49 PM
Yazan
Apr 25, 2013 08:07 PM
fxdxrdr
Jun 29, 2012 07:52 PM
willie37
Jul 3, 2009 03:48 PM
ywhat2000
Jun 25, 2008 07:56 PM
