polk mm
Old Mar 6, 2023 | 09:12 PM
willybsure's Avatar
willybsure
5th Gear
Default polk mm
new here i have polk mm 6.5 in dash and polk mm 6x9 in lids with a kenwood amp it says 50x4 was wondering if these speakers could handle a soundigital evops 800.4 if so what would you set high pass to on speakers
Old Mar 6, 2023 | 09:17 PM
fastsoup's Avatar
fastsoup
Just threw in a set of Polk Mm652 in my tour Pak off a 1200.4 with about 175w crossed at 80hz...they absolutely rock...so yes...feed em an 800.4 with voltage set to 23v crossed at 60hz
Old Mar 6, 2023 | 10:22 PM
willybsure's Avatar
willybsure
5th Gear
amp on way . so high pass at 80 on 6.5 at 23v and high pass at 60 on 6x9 at 23 v sound like a good place to start ??
Old Mar 6, 2023 | 10:27 PM
fastsoup's Avatar
fastsoup
Let's back up...what year bike & HU? DSP in play?
Old Mar 6, 2023 | 10:43 PM
willybsure's Avatar
willybsure
5th Gear
road glide custom a kemwood marine kmr-m328bt its just a cheaper unit it says 4 volt output .. no dsp
Old Mar 6, 2023 | 10:47 PM
willybsure's Avatar
willybsure
5th Gear
2013 bike
fastsoup's Avatar
fastsoup
Great unit...same one I have. Yes 4V...and goes all the way to max volume without distortion. Use a MM or Oscilloscope, 32 volume using a 1k test tone/bike running, I would set both front/rear channels to 23.6v. Put the amp to F and use the decks built in cross over to set Hipass to 60hz both front & back. Adjust to your liking from there but that should sound fabulous.
Old Mar 6, 2023 | 11:00 PM
willybsure's Avatar
willybsure
5th Gear
thanks for the direction hope to install this weekend it sounds pretty good now but hoping more power wakes it up
Old Mar 6, 2023 | 11:01 PM
fastsoup's Avatar
fastsoup
I assure you it will...highway speeds will now have more volume if need be.
Old Mar 8, 2023 | 05:48 PM
fastsoup's Avatar
fastsoup
Just the polks playing...everything else disconnected. 175w crossed at 60hz. I had the Neo's back there previously...the Neo's are definitely "louder" but there not warm at all...with a DSP the Neo's might be good...but without a DSP, the Polks are pretty spectacular. I must admit, when I removed them from the box, next to my Yellow Baskets and PRV 6MR500CF, these things felt like cheap plastic.
https://photos.app.goo.gl/vHjxMh5JZykFdZJV8
