Hd 50s headset
Old May 30, 2023 | 08:12 PM
bmartin18's Avatar
bmartin18
Stage III
Default Hd 50s headset
Hello all,
hd 50s dual headset with me and my wife. I want to use the bikes intercom when we use the scwelch button and i have all the vox disabled. But when making a noise such as coughing will still activate the intercom. Anyone have an idea how i can use the intercom only when I want to with the button? Thank you
Old Jun 1, 2023 | 05:36 PM
cycle7447's Avatar
cycle7447
Community Influencer
Originally Posted by bmartin18
Hello all,
Hello - looks like you are not too far from me.
OK, how about a bit more about your situation? What year bike are you riding. Do you have the GTS radio. Also, if you are using theHD50, are you trying to connect wirelessly. So, do you also have the WHIM installed?
Since you said you were pressing the squelch button, it sounds like you also have a CB installed.
From what I am reading from you, you are currently connected headset to headset - so are not using the bike system.
Old Jun 1, 2023 | 08:08 PM
hamah's Avatar
hamah
Not to hijack this thread but I'm also having trouble getting intercom using the HD 20S Evo headsets (with WHIM) working. I only want PTT (no VOX) to activate the intercom. I've turned off the CB (so as to not broadcast the conversation), turned on the intercom, and set VOX to minimum. In my case the reduced sensitivity seems to work as VOX doesn't kick in but then pressing the PTT doesn't work either.
Old Jun 2, 2023 | 06:41 AM
cycle7447's Avatar
cycle7447
When you press the PTT talk switch - do you see the intercom symbol light up? If so, this means it is working.
If working, try this, push the PTT switch and start to say something. At the same time, click the volume button up. It might be what is needed.
I don't have the WHIM - but, I just did this with my wired headsets. Went to vox and completely turned it down (not off - just down). Pressed the PTT switch and the light came on and I was able to hear the intercom.
Old Jun 2, 2023 | 03:25 PM
bmartin18's Avatar
bmartin18
Stage III
i have a 2014 ultra limited FLHTK. when I hit the squelch (PTT) i see the intercom light up, so its working, but I only want it to work when hitting the ptt. Right now it reduces the music if I cough or other road noises the vox picks up. I have it disabled and when i try to go into the vox settings through the bike the menu hangs on it and I have to cycle the ignition to get back to the main menu. 4.3 boom radio.I have a WHIM installed.I want to connect to the bike so we both can listen to the radio and be able to talk to each other. Thank for any input.
Old Jun 2, 2023 | 04:33 PM
cycle7447's Avatar
cycle7447
Did you turn the volume up while talking into the mu.
You should also have a setting for your wireless headsets - make sure the vol is up.
Old Jun 5, 2023 | 12:13 PM
hamah's Avatar
hamah
Thanks! I had no intercom symbol and when I went to Home/Setup/Com I only had CB and no intercom. My problem was I had inadvertently disabled the intercom when I was last using my Centurion to setup the GTS. Just had to re-flash the GTS to re-enable it.
Old Jun 6, 2023 | 05:31 AM
cycle7447's Avatar
cycle7447
Glad to hear that you got it working.
Enjoy the ride
TheOtherBob
Audio Systems
Oct 20, 2024 07:49 PM
El_Supremo
Audio Systems
Apr 15, 2022 01:45 PM
UltraV
Oct 24, 2021 07:52 AM
wb0zrd
May 30, 2014 09:15 AM
*Merlin*
Aug 3, 2010 03:44 PM
