Dayton DSP-408 speaker level issue
Old Aug 1, 2023 | 12:59 PM
Gypsy613's Avatar
Gypsy613
Default Dayton DSP-408 speaker level issue
Hey guys
Having some issues with my Dayton DFSP-408 after I wired it to my GTS Boombox through the speaker level inputs.
I have thre front stage going from the Dayton to a SoundDigital 800.4 then to a set of mmats in the front and lower fairings.
The rear stage is going to the rear saddlebag where I have a set of shallowmount Skar audio 8" subs and compression horns in the bag lids powered by a DS18 4000.5 claiming to do 900 watts at 1ohm (that didn't happen)
My question is that for some reason I'm not getting full signal to the amps , everything is maxed on the ds18 and I get bass but not 900 watts of it.The front stage sounds great at about 1/2 gain and the entire system comes alive when I use the streaming feature on the app but when I go that route I lose all my handlebar control options and have to use the remote ****.
Checked my wiring , talked to ds18 , talked to Dayton ... no answers. I'm just about to return the DS18 amp but wanted to reach out here first.
I recently tried running the ds18 at a 4 ohm load sounded exactly the same as 1 ohm but alittle clearer no volume difference.
Thanks in advance guys
Reeve
Old Aug 1, 2023 | 01:48 PM
Circa58's Avatar
Circa58
what is the master volume set at, bottom right corner
Old Aug 1, 2023 | 02:29 PM
Gypsy613's Avatar
Gypsy613
master is full
Sub channels (7+8) on dsb maxed as well
R
Old Aug 1, 2023 | 07:58 PM
Dsm Limited's Avatar
Dsm Limited
How do you have that DS 18 amp wired that you think you should have 900w? The 900w comes at a 1 ohm load. If you have 2 - 4ohm speakers wired parallel, it creates a 2 ohm load.
All that said, I know nothing of DS18 amp performance in the real world. Some amps create rated power, some don't come close. Some create rated power with a crappy signal.
If their amps perform as well as their speakers, that could be an issue.
Old Aug 1, 2023 | 08:14 PM
Gypsy613's Avatar
Gypsy613
2 dual voice coil 4 ohm subs wired in parallel which gives me 1 ohm
The amp is rated for 1 ohm but doesn't do it ...RMA'd the amp
Old Aug 2, 2023 | 08:01 AM
Babyboy's Avatar
Babyboy
What flash are you using with the GTS headunit??
Old Aug 2, 2023 | 02:23 PM
Gypsy613's Avatar
Gypsy613
using the RF 8 speaker flash
Old Aug 2, 2023 | 02:47 PM
Babyboy's Avatar
Babyboy
If using the Techno Research to flash the bike there is not a RF 8 speaker flash. Just the recommended RF flash for 14 and new bikes.
The only 8 speaker flash is either HD or SOUNDZ at this present time.
BTW my techno software just updated again so all the latest and greatest are in the program
Old Aug 2, 2023 | 03:18 PM
Gypsy613's Avatar
Gypsy613
Attachment 625955
The RF is the one I have , when deciding it was the flattest
Old Aug 3, 2023 | 02:13 PM
cshocker's Avatar
cshocker
And you've messed with the input selector on the DS18 amp?
How many RCA do you have going from Dayton to DS18 amp?
VintageWest
Audio Systems
Oct 17, 2022 12:11 PM
big_tony
Audio Systems
13
Dec 22, 2018 11:57 PM
serioussv3n
Oct 19, 2017 09:56 AM
GARY DYER
Aug 25, 2015 01:47 PM
Lawdawg
2014-2024 Touring Models
May 28, 2015 02:25 PM
