Audio Noise
Old Aug 23, 2023 | 04:43 PM
SSG_B's Avatar
SSG_B
Default Audio Noise
I have a Soundstream HDHU14+, with Precision Maa4.400 amp. Hertz Neos in fairing, Mmats 6.5s in lowers, Herts 6x9 Neos in bags. All wiring from Volunteer audio, nothing cut or spliced. With the bike running I am getting a whining noise that increases with the throttle. After a bit of speed you cant hear it but I don't feel as though that noise should be there. Especially after spending a few K. All wires are tight, battery wire is not run near speaker wires. I have also added a zero gauge ground wire from the battery to the frame. Any other things to look into this issue at?
2018 FLHTK
Old Aug 23, 2023 | 05:55 PM
kloccwork419's Avatar
kloccwork419
You bought all that from volunteer and they recommended running it all on that single amp? Sounds to me like its pushed to its limits
Old Aug 24, 2023 | 06:02 PM
SIX6ONE's Avatar
SIX6ONE
I have been looking at these same head units from Volunteer Audio and in ALL the youtube install videos they mention you need to use the high-level inputs (speaker wire connection, NOT RCAs) when using an amp or you will get noise. Check out the vids or call and verify with them. This may be your issue.
Old Aug 24, 2023 | 06:23 PM
SSG_B's Avatar
SSG_B
Thanks for the replies. I have no rcas. The whole install was all pre wired plug and play.
Old Aug 25, 2023 | 05:43 PM
SSG_B's Avatar
SSG_B
Amp is out and going back to get tested and probably replaced. I was also thing about upgrading the amp after that. I have a Dayton dsp I have not installed and was thinking maybe’s a 1200.4. If I put the tour pack back on then I will need to upgrade those speakers as well. At that point maybe 2 1200.4s. For now, just some music will be nice
Old Aug 26, 2023 | 01:31 PM
hamah's Avatar
hamah
When you say the noise "increases" with throttle do you mean in volume or in pitch (higher pitch with increased engine revs)? If the later then what your likely hearing is stator (alternator) whine and is usually caused by a voltage potential between the ground points used for your HU and amp. To test you could disconnect the amp ground and temporarily connect it to the frame of the HU using one of the HU's mounting bolts.
There are a ton of threads here and articles out there on troubleshooting and resolving if this proves to be the problem.
Anyway, let us know what they find. My guess is the amp will probably test fine.
Old Aug 28, 2023 | 10:51 AM
SSG_B's Avatar
SSG_B
Thanks for your reply. Its not the pitch that changes but the volume of the noise increases. Hopefully I will have some answers from VA this week. If the amp is good then not sure where to look from there. Maybe ground the amp to the radio as has been suggested. Also I guess I can move the power and ground wire and re-route them.
hopefully this video works
https://youtube.com/shorts/jCjOAytq2...yXO5S97kO57Oa_
Old Aug 28, 2023 | 11:58 AM
hamah's Avatar
hamah
Maybe I'm missing something. First, the engine isn't running at all so I don't know hat you mean with "increases with throttle". Secondly, while I heard hiss/static I did not hear any "whine" (nor would I expect to with the engine off). The noise does sound rather loud but then again you are holding the phone close to the speaker in an otherwise quiet environment. The noise does not decrease when you reduce volume so it's not likely originating at the input stage of the amp. Are you sure you posted the correct video? In this case it might not be a bad idea to have the amp checked or swapped as you've said you're doing.
Old Aug 28, 2023 | 01:20 PM
SSG_B's Avatar
SSG_B
I did not get a video of it running before the amp came out, you didn't miss anything therefore no whine to hear with that video. The noise is very prominent with the engine running as well and outdoors. Ill keep this thread updated on what I hear from VA when they get the amp. Hopefully that is the issue and I don't need to start the trouble shooting process all over. I will however be in the market for a larger amp at some point to push all the speakers the way they should be.
Old Sep 5, 2023 | 02:19 PM
SSG_B's Avatar
SSG_B
Just wanted to follow up on this. The amp had issues so I upgraded to the Hertz 4.900 instead of getting another 4.400 Precision. Thanks for all the replies and suggestions.
