Boom radio CVO GPS install
Old Sep 7, 2023 | 07:41 AM
Medevack1's Avatar
Medevack1
Default Boom radio CVO GPS install
Hi, I need help. hopefully someone can guide me in the right direction. I came across a CVO Boom Radio with GPS and Siri, I have a 2008 RK with aftermarket batwing, My question is since I only have the radio with the GPS antennas and other radio antennas but no plug can the radio be hard wired?
Old Sep 7, 2023 | 07:53 AM
ange d mange's Avatar
ange d mange
Sadly, I believe you may be out of luck in a pre-2014 bike.
Old Sep 7, 2023 | 08:01 AM
Medevack1's Avatar
Medevack1
So is not like an aftermarket radio where it can be hotwired? What else would i need besides the Radio and antennas?
Old Sep 7, 2023 | 08:07 AM
ange d mange
The hotwiring part of it is well out of my scope of knowledge.
I just stated the fairly obvious, that the plug and play aspect was probably not gonna happen.
Wish my replies were more helpful. Best of luck.
Edit: Guess I could have read and comprehended your original post before I replied...
"My question is since I only have the radio with the GPS antennas and other radio antennas but no plug can the radio be hard wired?"
Old Sep 7, 2023 | 08:19 AM
cshocker's Avatar
cshocker
Yeah just add a CAN BUS network and you'll be good to go!
Old Sep 7, 2023 | 09:08 AM
Medevack1's Avatar
Medevack1
I see they make aftermarket cam bus through J&P cycles. I'm sure that's not a plug and play since I have an 08 RK should i just stick to my Garmin and forget about the CVO radio GPS?
Old Sep 7, 2023 | 01:13 PM
scott_0's Avatar
scott_0
you'd be much better off going with the soundstream head unit made specifically for your year...
Old Sep 7, 2023 | 08:27 PM
Medevack1's Avatar
Medevack1
my RK has an aftermarket batwing I don’t think my RK Police came with a radio harness
Old Sep 8, 2023 | 07:06 AM
cycle7447's Avatar
cycle7447
Community Influencer
Good luck OP. You will have no difficulty selling the radio here.
Old Sep 11, 2023 | 07:51 AM
Medevack1's Avatar
Medevack1
So I got the radio and both antennas and they are in EXELENT condition, I looked and I found the plug for the radio on eBay so once I get the plug ill take a crack at installing it, if I can get power to it I wont have a problem installing it and making it fit... lol
