Which Aftermarket Speakers
Old Jan 27, 2008 | 05:51 PM
Slash's Avatar
Slash
Default RE: Which Aftermarket Speakers
ORIGINAL: Firetender
JBL and Infinity are good speakers? If you're going cheap, I'd go Polk (ONLY AN OPINION HERE BRO!) . If you want good speakers (or have deep pockets, or a nut like I am), you want Paradigm. Everybody starts somewhere with electronics, like you I knew nothing (I'm a chemist!). With an advanced speaker design book from your bookstore and a soldering iron, in no time you'll be wiring out-of-phase push/pull using high-end wire and state-of-the-art stuff that is timeless and not what every guy on your block runs.
The JBL's and Infinity's arefine speakers if you want to use them with the stock HD Harmon Kardon stereo which is designed to operate with speakers that have an impedance of 2 Ohms -that's why J&M and Hog Tunes offer 2 Ohm speakers.I doubt Polk even makes a 5 1/4" 2 Ohm speaker.
Please note re:Infinity Speakers - The 52.7i Kappa's have 4 terminals to connect toadditional crossover boxes (they're not small)that you'll need to mount securely someplace beneath the fairing.(I decided against them for that reason) Both JBL GTO's and Infinity 5022's connect directly to the leads from the stereo.I ended up swapping the 52.7i's forthe 5022's.
Old Jan 27, 2008 | 06:08 PM
lkr0's Avatar
lkr0
IMHO--this is the best combo if you do not want to put an amp in the bags
ORIGINAL: chuckk01
I just installed mb quart with hog wired amp. Sound is awesome.
Old Jan 27, 2008 | 06:10 PM
Bigredone's Avatar
Bigredone
JBL
Old Apr 30, 2012 | 01:56 PM
rieds's Avatar
rieds
1st Gear
I just installed the rockford pbr 300 mini amp. Fits great and sounds great now I just need to change the speakers. Anyone have any input on the 5 1/4 to 6 1/2 adapter rings. And do you have to use marine speakers. Thanks for any input.
Old Apr 30, 2012 | 08:13 PM
iccor56's Avatar
iccor56
does anyone have suggestions for audio on bikes with no fairing?
Old Apr 30, 2012 | 10:10 PM
rg_dave's Avatar
rg_dave
I have had 6.5" infinity kappas. They sounded good but are on the "tinny" side. I am now running Polk MM 651. They sound much richer in my opinion. I also ran the Arc mini amp with both.
Old Apr 14, 2013 | 02:24 PM
JMJOHN's Avatar
JMJOHN
Sponsor
more good info here http://www.jmcorp.com/SeeProducts.asp?PF=47 ,,,,, and here
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
billnourse
May 13, 2015 06:37 AM
Choppie
Audio Systems
Apr 2, 2013 12:44 AM
WHOSNEXT
Aug 23, 2011 04:59 AM
Akitakoi
Mar 31, 2009 10:43 PM
PSO169
May 7, 2007 07:31 PM
