speaker wires
Old Feb 9, 2011 | 09:50 PM
bigdog1949's Avatar
bigdog1949
Default speaker wires
I have an 07 flhtc ,question ,are there speaker wires from the factory installed,put on speaker boxes on tour case, still lookin
Old Feb 10, 2011 | 09:09 AM
Harleypingman's Avatar
Harleypingman
No, HD does not include the wiring for rear speakers on an Electra Glide Classic or any other non-Ultra radio-equipped model.
Carl
Old Feb 10, 2011 | 09:20 AM
coolerman69's Avatar
coolerman69
You can buy the wiring harness from HD to run your rear speakers. There should be an empty place on the back of your stock radio for it to plug into.
Old Feb 10, 2011 | 04:40 PM
Harleypingman
If you are using HD's rear speakers and want the HD parts to connect them on your EGC, you'll need two harnesses. For connecting to the speakers, you'll need p/n 77157-06 which carries the wiring from the speakers to inside the fairing. Then you'll need the non-Ultra overlay harness, p/n 70169-06 to connect the speaker harness (HD calls it the "audio harness" IIRC) to the HK head unit. The first lists for about $97; and the second about $120.
With the help of the parts book, you can buy the connectors and pins/sockets that go onto the ends of the wires for insertion into the connectors for a lot less, as well as buying ordinary speaker wire.
Carl
Old Feb 10, 2011 | 06:02 PM
bigdog1949's Avatar
bigdog1949
thank you,theres a hd used parts place in ocala i'll buzz them see if they have the wires,if not i'll wire it up myself,thanks again for the quick reply
Old Mar 1, 2011 | 09:48 AM
rodman4196's Avatar
rodman4196
1st Gear
Default rear speaker question
I have a 09 Road Glide that I installed the cb radio in last year. I am installing the lowers and speakers to the bike. I purchased the non ulta overlay harness when I installed the cb. I have all the brackets etc for the lowers (lower at the painters). Do I need another harness to hook the lower speakers to the rear speaker? I had the bike flashed for the fader control last week. Thanks for any help.
Old Mar 1, 2011 | 10:49 AM
Harleypingman
When I installed the 2011 CVO SG speaker boxes on my bike, I used the same harnesses from the speakers to the fork neck used on the CVO. It required additional connectors to mate with them at the fork neck. The part nos. and description are in this thread:
https://www.hdforums.com/forum/touri...ed-w-pics.html
You don't have to use the HD harnesses from the speakers; I did to provide a quick disconnect.
You will need to access the rear speaker pinouts with additional wiring from those pinouts to the speakers in the fairing lowers. You can do it using the passenger connectors (they're labeled) on the NUOH since they also contain the rear speaker wiring, splicing the rear speaker wires at the 35 wire connector, or removing the rear speaker wires from the 35 wire connector and replacing them with wires going directly to the fairng lower speakers in which case you'd need the sockets that go on the end of the wires prior to insertion into the 35 wire connector.
Good luck with your project.
Carl
Harleypingman
Audio Systems
34
May 2, 2023 09:42 AM
UltraBrian
May 8, 2017 06:07 PM
Rsand
Audio Systems
Aug 28, 2012 07:30 AM
andyp
Jan 17, 2009 05:22 PM
mvinc01
Mar 10, 2008 06:18 PM
