UltraNutz..new system
Old Feb 11, 2013 | 05:51 PM
  #111
lowrider 2007's Avatar
lowrider 2007
Stage IV
Thanks' that is going to be a huge improvement. What speakers would you recommend?
Old Feb 11, 2013 | 06:04 PM
  #112
UltraNutZ's Avatar
UltraNutZ
you have the arc speakers now? if so I would stay with them and put the amp in, then upgrade them if you don't like the outcome to something like the Polk DB651 or the Focal. All depends on what you want to spend. I would certainly try what you have first, you just might like it and no sense spending $ if you don't have to.
Old Feb 11, 2013 | 06:41 PM
  #113
OLD MXR's Avatar
OLD MXR
Ok UltraNutZ I just installed a soundstream amp and polk audio speakers on a 12 streetglide getting a loud pop when this system comes on and shuts off. What could be wrong?
Old Feb 11, 2013 | 06:43 PM
  #114
UltraNutZ's Avatar
UltraNutZ
if you turn off the radio then turn to accessory, do you hear the pop still? need to figure out if it's coming from the radio or the amp.
Stock radio?
Old Feb 11, 2013 | 06:44 PM
  #115
GLACIERPEARL's Avatar
GLACIERPEARL
Could it be the weasel ??? Couldn't help myself ?
Other than the pop, does everthing function properly ??
Old Feb 11, 2013 | 06:45 PM
  #116
GLACIERPEARL
Bad ground possible.........
Old Feb 11, 2013 | 06:48 PM
  #117
UltraNutZ's Avatar
UltraNutZ
lol GP...
here's a couple of tricks to try.
  1. did you grind off the paint where the ground attaches to the fairing bracket? ground loops can be a biatch to troubleshoot but to start you've got to make sure you have a good solid ground.
  2. if the above is ok, take a piece of wire and ground the chassis of the radio to the same location as your amp is grounded to and try it again.
Old Feb 11, 2013 | 06:50 PM
  #118
UltraNutZ's Avatar
UltraNutZ
great minds! :-)
Old Feb 11, 2013 | 06:51 PM
  #119
GLACIERPEARL
Is the amp wired through the orange radio remote wire ??
Old Feb 11, 2013 | 06:52 PM
  #120
GLACIERPEARL
Could also be a delay in the power off through the remote wire, if he's using that.
