Re-location bracket modified for SS Amp
Old Jan 30, 2013 | 11:22 AM
Nitro NHRA's Avatar
Nitro NHRA
Default Re-location bracket modified for SS Amp
In keeping the HK Head and using Scotts Re-Location bracket. Here is what i did to secure the Sounstream 4.520 amp to the bracket. I used 2 pieces of 3/4" angle iron cut 1" long. 1 piece 1/8" x 1" cut to the length of the amp(from tab to tab). The angle is welded flush to the front edge of the riser on the bracket. This position allows the amp to sit far enough back so there will be plenty of clearance with the fairing. Once i welded the angle on, i set the amp on top to position the rear piece of flat stock. Clamp and weld. set amp back on, mark the hole locations. Remove amp and drill holes. touch up with some black paint.
Attached Thumbnails Re-location bracket modified for SS Amp-img_0114.jpg   Re-location bracket modified for SS Amp-img_0115.jpg   Re-location bracket modified for SS Amp-img_0117.jpg
Old Jan 30, 2013 | 11:28 AM
UltraNutZ's Avatar
UltraNutZ
that's awesome Nitro NHRA, great work.. thanks for sharing sir...
Old Jan 30, 2013 | 11:31 AM
Nitro NHRA's Avatar
Nitro NHRA
I Should thank you It was you that started me out on this fun little project. Just have to finish wiring in the amp and then its jam time.
Old Jan 30, 2013 | 12:09 PM
ratdoc's Avatar
ratdoc
Very cool work...
ScreamingSkulls
Audio Systems
Mar 22, 2016 12:51 PM
AAWAV
Audio Systems
11
Feb 6, 2015 01:00 PM
JoeN
Audio Systems
Apr 17, 2014 08:43 PM
rome304
Audio Systems
24
Jul 1, 2013 04:58 PM
jeff.georgalas
Aug 22, 2010 08:54 AM
