6 Speakers off SS 4.520?
Get a set of DB651 Polks, drop them in the lower fairings, run them in parallel with the HATS to bring your load to 2ohm at the amp. That takes care of 1 RF amp.
A set of Polk MM691 with the CS lids and use the other RF amps for that.
This keeps boths amps running at a stable 2 ohm load.
IMO, the SS in a better selection for an amp but unless you're just wanting to trash your existing amp investment, why not try it in a different configuration. If it still fails to meet your expectations, then you simply get a SS amp, and you're still good with your impedance/ohms configurations as wired and run that setup instead.
That PBR 300x2 is a great little amp if it's setup up properly.
Thx for the quick reply. I think i did poor job of stating my question. I already have the SS and the MM's just not installed. My current setup includes one 2 channel RF and a set of HAT's in the batwing. I wanted to add the SS inside the batwing to run the MM's but it doesn't look i have the room to have both the RF and the SS inside the batwing. So i was wondering if i could run all 6 speakers off of the SS and still get at least 100 watts rms to each speaker.
reason I ask is;
You might look into Scott's bracket here for this which relocates 2 modules on an Ultra below the stock radio on a shelf of it's own. That shelf I feel certain will hold that PBR300x2 amp without a problem. I have one of his brackets at the house that I never used so I can send it to you, if it works then we'll work out something (thinking $30)
If this works for you then the configuration I'd setup is the SS amp on the lowers and saddlebag lids, and run the PBR on the HATs.
That was my original plan I already have my RF mounted on top of my Sony HU using his bracket and I purchased his lower bracket with the intent of doing as u suggested. Once I opened up the Batwing to relocate the RF and add the SS i noticed that there is absolutely no room for that lower bracket. The neck on my SG is right there, so that's what has me wondering if I could run 6 speakers off of the SS.
That is unless you want to return the MM651s and get a set of DB651s (4 ohm) then you'd wire the lowers and fairing speakers in parallel to bring the SS amp load to 2 ohms and wire that to the front channel, then drive the MM691s with the rear channel..
