XM Radio upgrade question?
Old Mar 6, 2013 | 06:45 AM
rob0225's Avatar
rob0225
Default XM Radio upgrade question?
Does anyone know the difference between the two part #s?
76404-06
KIT, XM RADIO, BOOM! AUDIO HARLEY-DAVIDSON
and
76165-06A
MODULE, XM SATELLITE RADIO HARLEY-DAVIDSON
Also how do I know if I need a left or right side bracket for the antennae?
I have a 2010 EG Limited.
Old Mar 6, 2013 | 07:38 AM
UltraNutZ's Avatar
UltraNutZ
76165-06A is just the module
76404-06 is the kit, with harnesses
Old Mar 6, 2013 | 08:53 AM
rob0225's Avatar
rob0225
Thanks UltraNutz, so the kit should come with everything I need to plug n play?
Also, any idea on the antennae bracket? Would I need a left or right side bracket?
Thanks again!
Old Mar 6, 2013 | 09:18 AM
vhmike73's Avatar
vhmike73
Rob, I have a Street Glide, but when I was running HK components (including the XM module), the part number 76456-06 for the Antenna Bracket gave me a part that mounted on the clutch side of the inner fairing (when facing the bike- that translates to "Left Side Antenna Bracket" when sitting on the bike). The top right fairing bracket bolt was the bolt used to secure the bracket to the fairing. The bracket cost like $5 at the dealer.
Not sure if an EG Limited already has something there (if you're running a GPS or something).
Old Mar 6, 2013 | 09:20 AM
UltraNutZ's Avatar
UltraNutZ
ok i'm sorry I mis-stated above.
76404-06 is the kit but it doesn't come with harnesses. What HD calls a kit is nothing more than the module and the antenna. You still need the harness and antenna bracket. The bracket I had on mine was on the left side (sitting on bike) mounted inside the fairing at the top.
Old Mar 6, 2013 | 04:48 PM
rob0225's Avatar
rob0225
Help again please. What harness do I need? The instructions I've read are kind of confusing and I don't know which harness I need for my bike ('10 EG Ultra Limited).
Also, any idea why would the 76165-06A MODULE, XM SATELLITE RADIO HARLEY DAVIDSON is more expensive then the 76404-06 KIT, XM RADIO, BOOM! AUDIO HARLEY-DAVIDSON?
Thanks again.
Old Mar 6, 2013 | 05:33 PM
UltraNutZ's Avatar
UltraNutZ
I'm really not sure on the pricing. The 76165-06A is not even in the 12 or 13 parts catalogs anymore.
The HD harness is part # 70172-06
Old Mar 6, 2013 | 05:39 PM
rob0225's Avatar
rob0225
Thanks again Ultra. I also replied to your PM. Much appreciated!
kwwn15
Apr 9, 2013 10:51 PM
dhog
Feb 20, 2013 09:13 AM
zeus33
Apr 22, 2012 08:49 AM
Jukebox
Apr 22, 2010 08:00 AM
marlinman1
Dec 1, 2009 08:48 AM
