Soundstream and Polk db651's
Old Mar 20, 2013 | 03:36 PM
blue66's Avatar
blue66
Well...soundstream tech told me there is abolutely no internal changes between the old and new amps, other than the outside wire connections.......
However he also stated in 20years of car audio he has never heard of an amplifier causing radio interference and their amps put out no where close to a frequency that would even come close to fm interference. However a quick google of class D amps and reception seem to show otherwise. So there is a glitch on some instances of this combination. Hopefully we can get to the bottom of it eventually.
Old Mar 20, 2013 | 03:49 PM
WestTexasRanger's Avatar
WestTexasRanger
Word on the Street is that the Soundstream cases have a thin layer of lead installed in them. This protects our head units from the switching output interference and protects our amps from Kryptonite.
Last edited by WestTexasRanger; Mar 20, 2013 at 03:50 PM. Reason: Sorry for the non-informative Post - Trying to get to 300!!!
Old Mar 20, 2013 | 04:22 PM
UltraNutZ's Avatar
UltraNutZ
yeah he doesn't have a clue what he's talking about. Switching outputs by nature whether it be an A/C generator, a 12v converter, or an amplifier emit EMI. The trick is isolating that EMI and apparently the FCC doesn't do a real good job of policing that so the manufacturers get away with more than what's "allowed".
I'm hoping the statement above about using a thin sheet of lead inside the cases is true to fact with the new models.
Has anyone out there installed a new style PN4.520D with the speaker block on the side running a stock head unit and stock whip antennas verify that you have no FM interference issues?
Old Mar 20, 2013 | 06:38 PM
WestTexasRanger
MY BAD! My post was meant as a joke (hench the "wink"). I also edited my post (see edit note) to show that it was totally without merit and that I was just trying to achieve my 300th post milestone.
So in keeping Politically Correct, I ask the forgiveness of anyone who may have been harmed by my words. I promise to keep On Topic in the future and not to spread viscous lies & rumors.
Old Mar 20, 2013 | 08:09 PM
just plain john's Avatar
just plain john
John what did you pay for the amp sir? If the price is reasonable, I'll just buy it from you to use elsewhere and you can look at a different amp.
If you'll do the swap, if I do decide to swap, I'll just give it to you. I don't know how to troubleshoot an amp (no spark/fuel hah!), but I think something's wrong with it.
Old Mar 20, 2013 | 08:12 PM
UltraNutZ's Avatar
UltraNutZ
I took it as a joke as well. :-)
UltraNutZ's Avatar
UltraNutZ
ok just let me know what's going on. Have you purchased that antenna amplifier yet to see what that does for your reception?
Old Mar 20, 2013 | 08:13 PM
just plain john
Originally, I had the stock head unit and immediately lost fm reception, and my amp is I assume the latest version. It's on the bike less than a month.
Old Mar 20, 2013 | 08:16 PM
just plain john
Not yet, been busy the last few days but I will. Might try to source one locally from Radio Shack or maybe Fry's
Old Mar 20, 2013 | 08:35 PM
mtgriz's Avatar
mtgriz
I wonder if the tech hadn't heard of any problems with FM reception because up until recently few of these amps have been mounted almost directly on top of a head unit. Perhaps it's that close proximity of the amp to head unit that is causing the issues.
