Best audio setup 12 Ultra Classic
Old Mar 23, 2013 | 08:19 PM
chedderbandit's Avatar
chedderbandit
Default Best audio setup 12 Ultra Classic
I have a 2012 Ultra Classic Limited and want to replace the stock system with something that kicks azz. I was wondering if anyone had any advice on what to get. My budget is around $2000. I was thinking of adding lower fairing speakers, lid speakers and subs ( I like good bass). Also, I've seen the tweeters that replace the temp and oil pressure gauges on either side of the radio. Any thoughts?
Old Mar 24, 2013 | 02:29 AM
GLACIERPEARL's Avatar
GLACIERPEARL
Don't waste your time with 'subs'.........GREAT bass can be had with 6X9's, ..if the the freq is low enough, and they have PLENTY of POWER !!.........How much space are you willing to sacrifice ?/ Check out the link to my build in my signature line........... Can't be done for $2K,....but you'll get some greart ideas !!
Good luck !!
Old Mar 24, 2013 | 07:20 AM
just plain john's Avatar
just plain john
Check out the House Party kit. http://baggernation.com/products-stereo.htm
Old Mar 24, 2013 | 08:38 AM
GLACIERPEARL
Hard to consider 75W per channel a 'house' party..............shed,....maybe !!!
Some poeple like the convenience of paying someone to put together a package for them......it does come at a cost..........
You can EASILY put something together yourself, and have a better system, for a better bang for the buck...
The Rockford line sure isn't what it used to be.....
Old Mar 24, 2013 | 08:54 AM
chedderbandit
I read thru your link and have to give you props on a great setup Galcierpearl. It gave me a lot to think about. I'm not that knowledgeable about the different head units, amps, crossovers, etc. Not sure what combo would give me the best sound. I guess I have some research to do. I'm sure I'll be posting more questions. Thanks!
Old Mar 24, 2013 | 09:25 AM
GLACIERPEARL
You could spend ALL day searching through threads on here !! GREAT ADVICE from many different people.......... Your ears will tell you what is the best set-up for you.....At least you have some scratch to work with !!!
Once you decide on WHAT you want your system to be,.....the rest will fall into place !!
Old Mar 24, 2013 | 09:27 AM
UltraNutZ's Avatar
UltraNutZ
stay away from the PBR300x4 amp..
your options are pretty much limitless when it comes to this stuff.
first you have to determine what you want and expect before you begin buying anything.
then you have to determine what your budget is for this.
A very nice setup can be had for under $600 or as GP points out, they sky is pretty much the limit.
Old Mar 24, 2013 | 06:15 PM
chedderbandit
Ok. After some reading on the forum and some research I was thinking of the SS PN4.520D amp, Polk MM651s for the fairing and the tour pack pods and for the saddlebags I was looking at Infinity Kappa 693.9i 6x9's. I haven't looked into lower fairing pods and what speakers would be good there yet. How's this sound so far?
Old Mar 24, 2013 | 07:58 PM
UltraNutZ's Avatar
UltraNutZ
The key thing here is you want to match speakers to the amp to be able to utilize the amp to it's fullest.
Are you wanting to do 8 speakers total?
2 fairing, 2 lowers, 2 tour pak pods, 2 saddlebags.
Old Mar 25, 2013 | 03:12 AM
chedderbandit
At first I was thinking of replacing the stock fairing and tour pak pod speakers and adding tweeters in the fairing, lowers, the 6x9's in the bags and lid speakers. That would be 12 total. I was thinking more is better. The more I read the more I find that more is not necessarily better, just more noise. I want a a great sounding system without going overboard. So far the 8 speakers that you listed sounds like a solid system. Would adding the tweeters and lids improve on the sound quality? I usually ride without the tour pak.
