Audio system upgrade
Old May 14, 2013 | 11:44 PM
  #31
BrownSanta's Avatar
BrownSanta
I have the ss amp and the 651's on my bike with the stock HK head unit and what a difference!
Old May 15, 2013 | 12:21 AM
  #32
zxport123's Avatar
zxport123
Would the best two speaker set up for this 4 channel amp be the Polk mm651's at 2.7 ohms or a good quality 4 ohm speaker?
Old May 15, 2013 | 09:08 AM
  #33
GLACIERPEARL's Avatar
GLACIERPEARL
If you are running 2 speakers,..........you want a 2 channel amp. The Rockford PBR 300/2 is your best option.
Old May 15, 2013 | 09:13 AM
  #34
UltraNutZ's Avatar
UltraNutZ
when you're dealing with this stuff, matching components is critical to a good end result. If you've got a good stable 2 ohm amp, then use 2 ohm speakers.
And yes, the remote control will control everything on the head unit just as the handlebar controls will.
Old May 15, 2013 | 08:41 PM
  #35
zxport123's Avatar
zxport123
Default UltraNutz & Glacier Pearl Need advice !
Looking for a sound system upgrade consisting of a Sony head that is IPOD and USB compatible, 2 upper and 2 lower fairing speakers, and one amplifier, for my 2002 Electra glide. I have narrowed it down to.
(Head Unit)
Sony DSX-S310BTX
Sony DSX-S210X
(Amplifier)
Sound Stream PN4.520D, or whatever else you suggest.
(Speakers)
I have no idea what speaker combo would work best with this equipment, whether it be 2 ohm 4 ohm speakers. The polk mm651 is a favorite but don't know about it cause it is 2 ohm. If a 4 ohm speaker is required suggestions would be greatly appreciated.
Old May 15, 2013 | 10:22 PM
  #36
zxport123's Avatar
zxport123
Default Which focal speaker to buy
Focal has several 6.5 inch speakers, how are they rated in terms of performance?
Old May 15, 2013 | 11:48 PM
  #37
GLACIERPEARL
The head unit is going to depend if you want to stream music via Pandora through your phone. If so,.....the extra $$$ for the blue tooth option, is really all your getting extra.
Per Ultra Nutz,...........the rest will be ..........
The Sound Stream amp is the new '**** of the walk' for easy installation, and good power.
If you want/can install separate tweeters,.............the POLK MM6501 in the fairing, and the MM65 in the lowers will be the recommendation.
If you don't want the headache of the component install, 2 sets of MM651.
This is pretty much the standard system that Nutz recommends, and I would agree that for the $$$$$, it's a solid choice.
Just need an install kit with control module. Biketronics kit has the Automatic Volume Control, and Hawg Wired doesn't,...........but HawgWired has a nice metal chassis for the head unit.
BIKETRONICS KIT
HAWG WIRED KIT
Add in a set of speaker adapters for the fairing,........... Cycle Sounds Speaker Adapters
Some 10 gauge wiring & a fuse holder for the amp,....and your all set !!
Old May 16, 2013 | 12:35 AM
  #38
zxport123's Avatar
zxport123
Thanks Glacier Pearl!
Old May 16, 2013 | 12:56 AM
  #39
GLACIERPEARL
Focal makes a good speaker, but ...........unless you climb the ladder a few rungs, you won't be real impressed.
The Focal 165 KRC was the lowest on the rung that made my ears happy !! At almost $700 a pair,........most folks are gonna pass !!
Anything lower on the Focal ladder, didn't impress me .........
Old May 16, 2013 | 05:54 AM
  #40
zxport123's Avatar
zxport123
TThanks for the info I will definately pass!
