Soundstream 4.520 question
Old May 23, 2013 | 07:58 PM
2JADED's Avatar
2JADED
Default Soundstream 4.520 question
I am doing the UltraNutz (4) MM651 and SS 4.520 build on my '13 Ultra Limited. I am to the point where I am hooking up the amp, but the 4.520 I received doesn't have the same wiring harness explained in the instructions:
9. Connect the left crossover black/white wire to the green/black wire on the PN4.520D speaker harness.
Connect the left crossover black wire to the green wire on the PN4.520D speaker harness.
Connect the right crossover black/white wire to the violet wire on the PN4.520D speaker harness.
Connect the right crossover black wire to the violet/black wire on the PN4.520Dspeaker harness
Here is my SS 4.520:
Maybe I'm missing something... Please help!!
Old May 23, 2013 | 09:06 PM
Stucustom's Avatar
Stucustom
I just hooked mine up tonight. I assume that you do not have RCAs on the HU, that is why you are wiring it up. The amp sounds great. I am looking to replace my Polk Audio DBX with some MM series. I bet your system will sound even better.
Old May 24, 2013 | 07:03 AM
NascarGuy's Avatar
NascarGuy
I ran into the same issue when I did my install last weekend. Basically you have to solder leads from the wiring harness where you cut the rear speaker wires to make them long enough to get to the amp then connect the wires individually to the amp itself. I got with UltraNutz and he said there was a harness change made by the amp vendor since he make his instruction sheets.
Old May 24, 2013 | 07:14 AM
derk8088's Avatar
derk8088
Ur on the right track the old style amp had a harness coming out by the power and ground and remote input, the newer style(yours) has a block style, so you have to run the crossover wires directly to the amp. The harnesses in ur first pic is the high level input from your head unit and the bulky block on the other side is where u run ur crossover to that side is the output side. On your crossover wires the positive is black w/ white stripe and the negative is black, so if ur hooking up your right front speaker run the crossover wires to the rf output of the amp and left front crossover wires to the lf output and so on
Old May 24, 2013 | 07:24 AM
2JADED's Avatar
2JADED
Thanks guys...much appreciated!
Old May 24, 2013 | 11:17 AM
2JADED's Avatar
2JADED
Figured it out...thanks for the help guys! Now I'm Rock'n and Roll'n!!!
2007z71
Audio Systems
Jul 23, 2014 10:28 PM
DeneFXDWG
Audio Systems
Apr 15, 2014 11:02 AM
SD2010FXDWG
Oct 11, 2013 08:53 PM
Natureboy007
Audio Systems
Apr 23, 2013 09:52 PM
dman5000
Audio Systems
Apr 21, 2013 04:48 PM
