mounting xm module AFTER amp install
Old Jun 13, 2013 | 07:50 PM
kneichko's Avatar
kneichko
Default mounting xm module AFTER amp install
I did the pbr300x2 amp install on my 2012 street glide. mounted the amp on top of HU with Velcro(thanks nutz). thinking of adding an xm module down the road. where are they be mounted? plus is Harley's module the best to use with stock hk deck?
Old Jun 13, 2013 | 08:38 PM
rbferg's Avatar
rbferg
Forum member Scott Ezzell makes a great bracket to relocate modules under stock HU, or you could use heavy duty velcro. The Harley XM module is the only one available for the stock HU.
Attached Thumbnails mounting xm module AFTER amp install-q0tfbywz-isqd0axd1hshp436gkoyjyq4pra_t0r3gw.jpg
Old Jun 14, 2013 | 07:30 AM
UltraNutZ's Avatar
UltraNutZ
you can use scott's bracket or simply use the same velcro and an added zip tie for security and stick it right under the stock head unit.
The HD model is the only one that will give you direct control of the device through the stock radio.
Just FYI, a lot of folks are complaining about having the stock head unit at a certain volume on the radio or cd setting then switching to the xm setting and volume being quite a bit less..
Old Jun 14, 2013 | 08:50 AM
kneichko's Avatar
kneichko
Ill do the Velcro zip tie. Bracket does look nice, should have gotten it before the amp install. Thanks guys.
Old Jun 14, 2013 | 01:36 PM
rbferg's Avatar
rbferg
The way Scott's bracket is designed, it will slip right in. I think you have to unplug one harness, of coarse you would have to detach your amp from the velcro on HU with a screwdriver or an air-chisel LOL. I like it because it allows air to flow around amp and HU and helps dissipate heat from the amp, plus it makes for a great looking install.
Old Jun 14, 2013 | 03:47 PM
GLACIERPEARL's Avatar
GLACIERPEARL
Who will know ??? LOL !!!
Old Jun 14, 2013 | 03:56 PM
rbferg's Avatar
rbferg
I will LOL!!! Plus, I'm not a big fan of velcro...
Old Jun 14, 2013 | 08:30 PM
sanman4ever's Avatar
sanman4ever
How the hell does that thing fit under the hood of a batwing? Mine seemed awful tight especially since I used the humongous non-ultra overlay harness?
Old Jun 17, 2013 | 04:15 PM
rbferg's Avatar
rbferg
It straddles the stock HU perfectly and was designed for the RF but will work with others. The bracket mounts just like the modules would normally be installed with space under HU to relocate the modules. I used the overlay harness as well with no issues other than a few extra zip-ties, it works great. I believe Scott also makes one for amp only if you don't have modules.
Attached Thumbnails mounting xm module AFTER amp install-img_0302.jpg   mounting xm module AFTER amp install-img_0310.jpg
Old Jun 20, 2013 | 02:14 PM
SDVmnt's Avatar
SDVmnt
I velcro'd mine below the radio. Ran some zip ties around the works to make certain it doesn't come off unexpectedly.
I'm selling mine as soon as I take the time to remove it.
CD sounds amazing, Radio "ok", and the XM Module is a step below the radio imo. Not happy with the sound quality of the XM module.
Modified the Non-Ultra harness to only have the parts necessary to power/control the XM.
