Upgrading my Stereo
Old Jun 19, 2013 | 12:47 PM
Sire2Twins's Avatar
Sire2Twins
Originally Posted by Primetime_2
where is the best place to put a 2nd? and how? I may do bag lids some day down the road and would need a 2nd or go to the 4 channel RF
Check out this link for a second amp mount. Another forum member used the Hogtunes 2nd amp mount, which mounts on the brake side of the fairing, vertically. Haven't personally tried it, but contemplating it myself to run my rear pods. Looks more appealing than trimming down my guage bezels and trying to mount two side by side (which also can be done)
https://www.hdforums.com/forum/audio...ing-plate.html
Keep in mind that, If you decide to switch to the 300x4 instead of adding a second amp in the future, you are going to also need to replace your fairing speakers at that point. The MM651's won't work with the 300x4 as it is not 2 ohm stable.
Have fun.
Old Jun 19, 2013 | 01:46 PM
Ultra rider2012's Avatar
Ultra rider2012
I got something in my email not long ago from Amazon (I think) about the Rockford BR amps it said that Rockford recommends that you run the ground wire from the Amp to the negative side of the battery Not to the forks. They said something about the ground path wasnt good through the bearings and it was causing problems. I will post the email when I get home.
Old Jun 19, 2013 | 05:47 PM
UltraNutZ's Avatar
UltraNutZ
Yeah I'd like to see that email please. Can you forward to me at ultranutz at outlook dot com please.
Old Jun 19, 2013 | 05:48 PM
UltraNutZ's Avatar
UltraNutZ
If you've got a SG model then I see no reason this hogtunes amp plate will not work for you. On the Ultras, I don't see how it will work.. Too much wiring in there...
Old Jun 19, 2013 | 05:55 PM
Primetime_2's Avatar
Primetime_2
Have fun.
Thanks for the info! looks like it will be another RF amp and 2-6X9's of my liking down the road sometime!
Old Jun 19, 2013 | 07:23 PM
Ultra rider2012
well I cant upload it here. I did forward it to Ultranutz. Let me know if you don't get it.
Old Jun 19, 2013 | 07:27 PM
UltraNutZ's Avatar
UltraNutZ
and here it is...
https://www.dropbox.com/s/8044wxwxqs...llAdvisory.pdf
Old Jun 19, 2013 | 07:41 PM
EZ STREET's Avatar
EZ STREET
Thumbs up
Originally Posted by UltraNutZ
Thankz for the heads up planing on doning the install Friday night
Old Jun 19, 2013 | 08:16 PM
ironman2011's Avatar
ironman2011
Just throwing it out there. On the grounding "through the bearings" issue, am I correct in saying that you would be fine if you ground to the frame say right in front of the fuel tank? It takes the bearings out of the equation.
Old Jun 19, 2013 | 08:52 PM
UltraNutZ's Avatar
UltraNutZ
you would be correct...
