Blown!!
Old Jun 24, 2013 | 10:56 AM
chunngle's Avatar
chunngle
I am sure that is easy to do if one tries hard enough. was that when you were experimenting with the bridging?
Old Jun 24, 2013 | 11:05 AM
UltraNutZ's Avatar
UltraNutZ
yeppers... still can't bridge that amp.. can bridge the 2.350d just fine..
Old Jun 24, 2013 | 11:09 AM
chunngle's Avatar
chunngle
if the big brown truck ever shows up I will be putting in the much anticipated and hard to find 4.520d and 7.1's this week
Old Jun 24, 2013 | 04:36 PM
vtdiesel's Avatar
vtdiesel
After reading the responses and also seeing a slight trend with the setup from what others have said maybe I should try something new or maybe I just had bad luck. Do I swap out the amp or the speakers? The amp would be easiest to do obviously. Who runs 4 Polk MM651's and what amp do you use if you've had good luck. I will say that I purchased my speakers from Sonic Electronix and they were effortless to deal with and they've already shipped out a new pair, great service.
Old Jun 24, 2013 | 04:40 PM
UltraNutZ's Avatar
UltraNutZ
been running MM651s for over 2 years (same 2 pair) and on the SS 520D for quite sometime (at least 6 or 8 months) now and nary an issue. Also running a set of Pioneer TS-D6902R 6x9s in the lids with a SS 350D
Old Jun 24, 2013 | 04:51 PM
vtdiesel's Avatar
vtdiesel
Must be my bad luck then UltraNutZ, my 3 month old CFR's are peeling chrome and rusting at the welds too. Thanks again
Old Jun 24, 2013 | 05:01 PM
UltraNutZ's Avatar
UltraNutZ
have you pulled the speakers out yet? are the tweeter posts angled or straight?
Old Jun 24, 2013 | 05:15 PM
vtdiesel's Avatar
vtdiesel
I haven't pulled them yet but they seem straight by looking through the grille
Old Jul 4, 2013 | 03:27 PM
loumik's Avatar
loumik
1st Gear
The system on my 2006 Road Glide is: HU=Sony MEX-BT4100P, Amp=RF PBR300x2, 2 fairing speakers=Polk MM651. The crossover switch was set to AP. The gain was set to 7. I seem to have blown the right speaker. I seem to be getting faint tweeter sound out of the speaker. The tweeter post is straight. I swapped connections and isolated the problem to the speaker. The woofer cone seems to be separated from the circuitry. When I gently depress the woofer cone toward the back of the speaker, something makes contact and the speaker seems to be playing at a normal level. When I release the cone, back to low level high frequency. Interesting theory on a bad run of speakers unless we are all setting them up wrong. Hopefully sonicelectronix will be responsive when I contact them tomorrow.
harley7316
Aug 25, 2017 05:30 PM
Marks57
Audio Systems
Jul 14, 2015 08:36 AM
JMJOHN
Audio Systems
Feb 26, 2014 12:51 AM
SwarleyManson62
Feb 21, 2014 04:16 PM
pretz
Mar 5, 2010 11:38 AM
