J&M speakers
Old Aug 13, 2013 | 01:48 PM
Bushy's Avatar
Bushy
Default J&M speakers
I currently have older J&M speakers with Tweeter and Mid Range Model HCUS-09GTM-c ], stock in rear.. I want to up grade to new system with AMp... Is it a issue moving speakers to rear and getting rid of stock>>.. I want to go with two new speakers and AMP from J&M rather the spend extra if not needed
thanks
will this model fit in the rear pods???
Old Aug 13, 2013 | 02:27 PM
sl33py's Avatar
sl33py
Which J&M speakers do you have currently? model or specifics. Reason asking is if they are the 7.25" speakers i don't think you can cram those into the rear pods...
Or do you want to move them to rear saddlebag lids? Those would fit the 7.25's.
Most look at the cost for speakers and amp and go self-install non plug-and-play to save $.
GL!
Old Aug 13, 2013 | 05:30 PM
Bushy's Avatar
Bushy
no they are stock size in rear,,and faring.... older speakers 5 1/4 I think so size is not the issue wiring is
Old Aug 14, 2013 | 06:50 AM
UltraNutZ's Avatar
UltraNutZ
Bushy the issue you're going to have is the grills. You can contact John @ J&M and he'll be able to provide a set of round grills for the rear pods. The grills you now have only work with the batwing fairings. But the woofer part of the speaker will fit no problem.
And to answer your initial question, yes you can move the fairing speakers to the rear and add additional J&M speakers and a J&M amp without issue.
Old Aug 14, 2013 | 07:34 AM
Bushy's Avatar
Bushy
Thanks
Old Aug 14, 2013 | 12:33 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Bushy
Here is a pic of the 4 upgrade-from-stock J&M's I was previously running. In the photo, you can see the the round rear speaker covers to which UN referred:
Another shot showing what they look like behind the grill:
I run the 7.25 XT's up front now and the Polk MM651s in my rear pods. They are being driven by an Arc 125-4 amp. I am very pleased with the results so far. Just hope the new Polks hold up...time will tell!
WestTexasRanger
Audio Systems
529
Jul 1, 2019 11:59 AM
Raineman
Audio Systems
25
Aug 7, 2017 10:33 AM
lnadler
Audio Systems
Sep 24, 2013 06:44 AM
fxlowboy
Audio Systems
Mar 18, 2013 05:56 PM
blue66
Audio Systems
Feb 26, 2013 09:26 AM
