amps on a 2014
Old Sep 2, 2013 | 03:13 PM
dusturbd's Avatar
dusturbd
Default amps on a 2014
any reason the RF PBR300 amps would not work with the new 14 ulta limiteds I would think the would install the same using the speaker wires as inputs into the amp.
Old Sep 2, 2013 | 08:00 PM
UltraNutZ's Avatar
UltraNutZ
based on what I've seen so far, yes it should work fine.
I'd be interested also in pics if you're changing front speakers. I'd like to know if something like the polk MM651 speakers will fit in those speaker housings in the fairing.
Old Sep 2, 2013 | 08:08 PM
Ultra rider2012's Avatar
Ultra rider2012
Do the 14 limiteds come with a boom audio amp ? I saw a limited with the front fairing off and there was a boom amp sitting on top of the radio
Old Sep 2, 2013 | 08:21 PM
dusturbd's Avatar
dusturbd
catalog shows the boom amp as and add on accesory
Old Sep 2, 2013 | 08:23 PM
dusturbd's Avatar
dusturbd
as soon as I get to it I will let you know as I have 2 sets of the DXI 650's setting here that I plan to install I can already tell you the rear pod speakers have the same bolt pattern as the DXI 650's I have already check the rears.
Old Sep 3, 2013 | 07:19 AM
UltraNutZ's Avatar
UltraNutZ
is my understanding as well.
Old Sep 4, 2013 | 01:23 PM
John_HD's Avatar
John_HD
It should work but I think the speaker plugs will give you a problem unless you are splicing wire. I will be doing mine soon (maybe look at it tonight even) and I know the speaker box adds another set of connectors.
GLYDN
Audio Systems
Sep 26, 2016 12:10 PM
13Ultra
Audio Systems
13
Sep 11, 2014 02:13 PM
mphillips21
Audio Systems
Aug 29, 2013 12:12 PM
GOSTAZ
Jul 18, 2010 07:46 PM
Abnmarine
Aug 3, 2008 12:01 PM
