The Official 2014 audio upgrade thread
Old Jan 21, 2014 | 06:11 PM
  #131
UltraNutZ's Avatar
UltraNutZ
awesome.. glad to see others trying different speakers. would you mind sharing what you did to countersink the screws in the rim of the speaker?
Old Jan 21, 2014 | 06:29 PM
  #132
ejvette's Avatar
ejvette
Well it wasn't as clean as I like there are proper bits for this sort of thing but it was a snowy day and I was working with I had in the garage I grabbed some longer sheet metal screws with thinner heads since the lip of the polks are much thicker than the factory speakers. I was really glad to see how thin the grills were. Anyway I used a standard 3/8 inch drill bit which was a little larger than the head of the screws and I would drill then test the depth with the screw until it was flush you can see in the pic I had plenty of lip to work with.
Old Jan 21, 2014 | 10:39 PM
  #133
MontyCop05's Avatar
MontyCop05
Originally Posted by ejvette
Installed my new amp and Polk mm651 speakers and boom grills. Who ever the sadist at the factory is that tightens down those 3 pain in the *** bolts I curse him lol. Thought I would share some pics. As montycop stated in the opening post I had to do some counter sinking to get the screw heads flush and used some longer screws also. As many have suggested I did lightly pack the pods with polyfil. These are the boom grills which are much deeper and thinner. And these are the tools I used which are similar to tools montycop posted the handiest to get at those PIA bolts is the flex head ratchet box wrench.
Ejvette,
Nice assortment. Close to what I used. I found that the stubby gear wrench with the flex head was the most handy...
Also I put in the poly fill but ended up removing it. It had a good effect on the stock speakers in my testing, but I actually felt the polyfill stifled my titans once I got then installed. It could just be me, but they seemed to be a little "muddled" with the addition of the polyfill.
Old Jan 22, 2014 | 06:33 AM
  #134
ejvette's Avatar
ejvette
Originally Posted by MontyCop05
Ejvette,
Monty I'm really not the audiophile that most of you guys are these things sounded so much better off the stock head unit before wiring up the amp. I don't think I can go thru another disassembly of those pods lol! But I ran the speakers off the stock head unit before and after the polyfil and it did seem like with the polyfil the bass was deeper and much richer.
Old Jan 22, 2014 | 07:16 AM
  #135
UltraNutZ's Avatar
UltraNutZ
Ejvette,
that's a first.. I thought I remember reading somewhere that you had put something else in addition to polyfil inside those pods?
Old Jan 22, 2014 | 09:06 AM
  #136
MontyCop05's Avatar
MontyCop05
I don't know T, it very well could just be me, or I may have used a little to much polyfill in the pods, (although I only used a handful in each). Those pods are quite small for the size of the titans.
Yes I was toying around with the idea of installing an acoustical vent in each pod, but decided against it for now. Being that the MoCo is having such problems with the flashes, I really just want to wait them out and see what a (working) flash will do for me before I start hacking up my pods. Bill has said the CVO 4 speaker flash sounds amazing but it's not viable yet for all of us consumers yet. The guy that is tinkering with the flashes for him has access to them and can remove and reinstall as he has problems. None of us can do that without countless trips to our dealer(s).
I'm also having a noticeable fade issue with my set up. The rear speakers, (Kicker CS67s) are noticeably a wee bit louder than the titans in the front. It's undoubtedly an issue with the internal DSP. I have to fade two notches to the rear to balance. This is another thing I'm waiting to be resolved before I mess around some more. At Bills suggestion I'm going to pull the fairing and switch the front and rear RCAs and see if the problem migrates. That will 100% confirm my suspicion that it's the workings of the DSP.
Old Jan 22, 2014 | 04:31 PM
  #137
barrygreen's Avatar
barrygreen
Here is the setup I suggest for those 3 bolts every one complains about, makes it so easy.
1/4 drive and a 7/16 wobble. 11mm for those who prefer metric.
Old Jan 22, 2014 | 11:25 PM
  #138
JMJOHN's Avatar
JMJOHN
Sponsor
here is what is coming from J&M for the 2014 Fairing position, rear pod position and Lower position http://www.jmcorp.com/ProductDetail....CRK-6652TW-RXX ,,,,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old Jan 24, 2014 | 09:51 AM
  #139
wwglide's Avatar
wwglide
For the 2014's, I see no polyfill need for the fairing speakers. For an Ultra, ss anything needed for the rear speakers or do you just drop them in as is?
Old Jan 24, 2014 | 09:55 AM
  #140
JMJOHN's Avatar
JMJOHN
Sponsor
depending upon how deep the speaker is you will install into the rear trunk pods, a spacer may be needed so that they will not bottom out inside (((see http://www.jmcorp.com/ProductDetail....URK-6652TW-RXX ,,,,,,,
