The Official 2014 audio upgrade thread
I played with the gain and frequency with the fairing off, radio on, and could never get a decent amount of bass out of it. I got a little more but not much. Before this when playing with the bass level control, there was no hear-able difference between -06 and +6, now i can at least feel a little bass.
Dont know if it is the limitation in the speakers or not. This is the first motorcycle that i have put an amp in but have been using them in cars for years. I am used to installing an amp and feeling the pop in the bass and volume. On the bike i have the volume bump but not the bass.
I was hoping taking the magic box out would help but, as stated, no difference (at least to me).
Wondering if i should try the HD speakers with the RF amp?
most amps have speaker level inputs. If that's what you have for an amp (no mention of it) then simply take your existing HD speaker wires and tie them into the inputs for the amp.
How did you guys affix the amp inside your fairing?
Where did you connect the remote wire?
I think I will be ready to install after I figure these things out.
set it on top of the head unit with velcro. I wrap a zip tie around them for good measure.
with speaker level inputs you don't use the remote wire. The inputs sense the voltage coming off the speaker output leads of the head unit and turns the amp off and on as needed.
get after it!
