The Official 2014 audio upgrade thread
Old Feb 18, 2015 | 10:22 AM
  #1231
fallenhillbilly's Avatar
fallenhillbilly
Thanks UltraNutZ.Sounds like it going to be awhile before the new limited sounds as good as the old street glide. .Harley has made something so simple so difficult for everyone who does not buy into their boom craps.and yes I have own the boom crap before. .no comparison to the Hawg Wired products. .just my opinion for what it's worth but thanks for your input. Will keep looking and hoping for a fix...For all of us. At least I'm not the only one with this Headache. .
Old Feb 18, 2015 | 11:36 AM
  #1232
dgreen1069's Avatar
dgreen1069
Originally Posted by UltraNutZ
I would not drill holes in these pods. remove the speakers and loosely fit the bottom portion of the pod with polyfil.
If you must drill holes, I would use an epoxy to seal them back up when done
I've seen a few threads where guys talk about porting the pods. Biketronics stated the pods don't have enough volume for good sound so they created brackets that use the open fairing instead of the pods.
I have the new Stage II speakers, and the rears definitely have deeper base because of the porting of the speaker pods. I'd be curious how porting the fairing pods would turn out.
Old Feb 18, 2015 | 12:28 PM
  #1233
Stopit's Avatar
Stopit
The pods are just small speaker enclosures and also the fairing support brackets. Bose has been vary successful making small enclosures sound big with innovative porting . They also spend alot on R&D to come up with those designs. I'm sure porting the pods would increase low frequency output , but getting it right is the key.
The brackets offered through Biketronics just open up the whole fairing ,which is isn't a true acoustic suspension or a tuned ported enclosure. This takes me back to car stereo in the mid 70's where you put a pair of 6 X 9's in the rear window shelf with the back side open to the trunk.
I understand there reason for this but I think if some one really crunched some numbers and had some time these pods could be effectively ported to get some impressive low end , there is a science to it .
Old Feb 18, 2015 | 12:54 PM
  #1234
CThompson27322's Avatar
CThompson27322
4th Gear
Couple questions I have with the Kappa 62.11i speakers on a 2015 SGS pod. Do I mount the Kappas on the inside of the pods or outside? If I mount inside, is there a gap between the pod and fairing where the speaker is facing the rider? If I mount outside, will I be able to use the Kappa's speaker grills or do I need to purchase Harley Boom grills?
Old Feb 18, 2015 | 01:52 PM
  #1235
Biketronics Inc's Avatar
Biketronics Inc
Former Sponsor
Hi,
It is mostly a flexing issue, once you try moving a lot of air with a decent set of speakers and amp you can watch the pods expand and flex. This added a lot of "muddiness" to any frequencies below about 400hz. Porting helped it some (tried a lot different port types and calculated proper size/length), not porting and using a loose filling of polyfill also helped. But I could never get an acceptable sound. I really wanted to use the pods and spent about a month messing with them. It would be better for us financially to use them. I think you can improve them some but not to a level that I found acceptable for a Biketronics product.
If you are using a lower powered setup, especially with a shallow speaker without a lot of cone travel, they might be ok. I tried a lot of parts and not surprisingly if the aftermarket speaker looked like a HD speaker it worked better.
Bill
Old Feb 18, 2015 | 02:52 PM
  #1236
Stopit's Avatar
Stopit
Originally Posted by Biketronics Inc
Hi,
Bill
So if the pods were a thicker or stiffer material then maybe porting would have been more effective or possibly achieved the quality you were looking for ?
Old Feb 18, 2015 | 03:18 PM
  #1237
JerseyGuy's Avatar
JerseyGuy
I think I have found part of my answer-- the rockford pbr300x4 wont run the kappas because they are 2 ohm-
anybody know if 2 rf's will even fit in the ultra-?
maybe the soundstream is the way to go?
anybody chime in on kappa's vs rokker xx? or titans?
thanks guys
Old Feb 18, 2015 | 03:20 PM
  #1238
Biketronics Inc
Former Sponsor
Potentially yes, even without porting. The pods in the new RG are a thick black material (ABS?), they do not have the same issue. And our rear pods are much smaller but very rigid and sound really good with the same speaker. So it is not a air volume issue and a port might not even be needed if the pod was solidly built like the new RG ones.
Bill
Old Feb 18, 2015 | 03:54 PM
  #1239
SunPilot's Avatar
SunPilot
I mounted my 62.11's on the inside of the pods. I have a SGS, but pretty much the same bike. I tried them on the outside like the originals, but the stock speaker grills hit the speakers. Mounted on the inside there is clearance and you can use the stock grills. I think they give better protection too. I think I posted some pics of my install...I'll see if I can find them.
Check out my posts... #1057, 1058, 1059 You can see what I did, and how I beefed up the mounts, which I think is a good idea. Hope this helps you.
Old Feb 18, 2015 | 08:10 PM
  #1240
JerseyGuy's Avatar
JerseyGuy
anyone?
