The Official 2014 audio upgrade thread
Old Jul 11, 2014 | 03:20 PM
  #731
bigh8840's Avatar
bigh8840
Anyone else constantly updating bt's website to see when they pop up? Lol
Found out the pods are going to be completely removed with bt setup.
Old Jul 11, 2014 | 03:56 PM
  #732
bigh8840's Avatar
bigh8840
Check that previous statement, just placed the order in for the kit. Hopefully have it installed within a day or two of receiving..
Old Jul 11, 2014 | 04:14 PM
  #733
SG1858's Avatar
SG1858
Just placed an order for the kit with BT4180 4 channel Amp. Should be here by the enf of the next week. Can't wait to listen to the sound!!!!!!!!!!!!!!!!!
Old Jul 11, 2014 | 05:11 PM
  #734
redeye93's Avatar
redeye93
Dangit can't add speakers to cart. Only with the 2180 amp setup. Anyone else having that problem on BT's site?
Old Jul 11, 2014 | 05:23 PM
  #735
SG1858's Avatar
SG1858
Call them to place an order. You might get little bit more discount as well.
Old Jul 11, 2014 | 05:31 PM
  #736
scarin's Avatar
scarin
Couple of question s for the collective and the experts. Running the PBR300 and the BT Titan I Is. I am in Arizona. Hot and nasty. Had the gain at around 8 and blew one speaker and the other now sounds like crap. Not sure what caused the problem. The HU is flashed.
Thinking about ordering the new BT 7.1s. Installing them and remove the titans and then get the titans replaced and sell them. So the questions:
1. From what's been said here the speakers should not have blown in this setup so thinking they were defective. Or is there something I'm missing?
2. Should I use the magic jack even though flashed? If so should I reflash or will it be fine?
3. Do I need to worry about the new 7.1s with the PBR?
4. Should I replace the amp?
Thanks for your input in advance.
Old Jul 11, 2014 | 05:52 PM
  #737
B BAD's Avatar
B BAD
Originally Posted by Mike Bradbury
Did you not need the boom grills because your speakers weren't thick enough to hit the factory ones? I just ordered the PBR 300x2 and the infinity kappa 62.11i speakers. I am still uncertain if I will need the grills. I just don't want to get in a situation where I need them when everything gets here and its time to install.
If you have the saddlebag speaker lids you are going to need the grills I have the infinity Kappa 62.11 5x7 speakers and they sound great also with the infinity Kappa speakers you have to trim all the plastic around the surface of the speaker and screw them into the saddle bag lid with a washer that will clip onto the top of the speaker to hold them in place along with the weatherstripping up under it in the saddlebag speaker lids. However the Harley-Davidson speaker lid do not come with the grills you have to purchase them separate.
Old Jul 13, 2014 | 03:13 AM
  #738
bedowinn's Avatar
bedowinn
Default PBR300X2 Kappa 62.11 install
Rounded up all the bits and went at it today.
The PBR300 went in easy with the mount I picked up.
I mounted the magic box on top of the amp.
Routed the 10 ga. power lines under the gas console with a 30A fuse 3" from the battery terminal. I did not remove the tank. I used the cig. lighter line to power the 3 port (forgot what it's called).
So far so good.
Went to remove the speaker pods and holy Sh*t, the inboard bolts were a SOB. 1 in particular (each side) required special attention. I finally managed to get them out using a 1/4" drive 7/16" socket. A battle worthy of a Hemingway novel.
The 4 speakers mounting tabs lined up with the existing holes so I just dropped them right in. You need to attach the wires to the speaker prior to mounted them with the screws as there is no clearance to get to the speaker wire screws once the speaker is attached to the pod half.
I tried installing the pods onto the fairing but stock grill interfered with the speaker. So I removed the stock grill.
I soldered and insulated with shrink tubing almost all of the wiring.
Many thanks to NJstreetglide and all the others that post on this forum for their insight.
In total it took around 6 hours with half that time devoted to 2 FU**ing bolts.
Old Jul 13, 2014 | 10:02 AM
  #739
sandmhale's Avatar
sandmhale
Default How's it sound?
So far so good.
So how is the sounds quality? Will you be buying some new grills now or going without? What made you decide on the Infinity over some other options. I'm still deciding what I'm going to get for speakers, but I'll definitely be doing the PBE300x2 and the magic box. I'm leaning towards Hog Wired 6.5's but also considering Infinity, Polk, and Kicker.
Thanks!
Old Jul 13, 2014 | 01:39 PM
  #740
z33k's Avatar
z33k
6th Gear
Default Just my 2 cents... J&M Audio
I've read through all of this thread and I'd just like to add my 2 cents.... I realize that a major subject of this thread is DIY audio, but I just wanted to comment.
Let me preface this by saying the obvious... Harley audio <=2013 totally sucked, and while the 2014 is much better it still sucks. It just sucks less.... Anyway....
My first experience with J&M was installing their 2 way speakers on my 2008 RG, no amp. The difference was night and day. Suddenly the audio was crisp and clear, and an amazing improvement over HD stock. Wanting even more, I did my research and I decided to step up to the J&M Rokker series amp and 7.5" 3-way speakers. Again, improvement by orders of magnitude and everything fit exactly like it should. Nothing needed rigging, and the performance was fantastic.
Later, J&M released their Rokker XX series amps and speakers. I was able to visit their trailer at Daytona Bike Week and asked about an upgrade. Mind you, this was two full years after installing my original J&M system. I spoke with John and his staff and they told me I could trade in my existing speakers and upgrade to the new line for $200... INSTALLED (try *that* with just about any other Harley audio manufacturer out there). They even took my original Rokker series amp and upgraded the chip and voltage regulator to the newer XX series components at no additional cost. I later transferred this setup to my 2012 RG when I traded. Almost 2 years later one of the 7.5" drivers had failed... I contacted J&M and they replaced it, no questions asked.
I now have a 2104 Ultra Limited.. The old system stayed on the 2012 RG when I traded in.. Obviously none of it would fit on the 14 (and it did help with my trade in value... Some)... Anyway, when I got to the point that I wanted to upgrade the audio, I again did my research (which included all of this thread, btw) and I decided to stay with the J&M. I ordered the two channel amp and speaker kit (I have take off hardware, so I run the rears unamped) from an official J&M dealer at significant savings from MSRP and did the installation myself. At this point let me interject that I would like to meet, in a dark alley, the HD engineer who designed those speaker pods and how they mount... But I digress....
The performance is again fantastic and everything fits just like it should. Could I have built a better sounding system, by specs, DIY? Possibly. Would I hear the difference? Probably not (and I do have experience in pro audio). Would I hear the difference at 80 MPH? Definitely not. I went with the J&M because of high quality, what I consider to be superior design/fit/finish/sound, and exemplary customer service.
I am not making any judgments on any of the other systems mentioned here.... I'm sure they sound great. I just wanted to share my experience with J&M with the forum.
Mike
