The Official 2014 audio upgrade thread
Old Jun 8, 2015 | 03:11 PM
  #1711
Ultra2014's Avatar
Ultra2014
6th Gear
Originally Posted by bucko72
Same speakers, use stock grills on tour pack. The grills were a tight fit and may be touching the tweeters but I could not tell for sure. Cycle Sounds said they would drop right in so I just put them in. It doesn't seem to affect the sound so I am not too worried.
do you have pt numbers of what you have. I want to get the same thing and only want to take the bike apart one time. would like to make sure I get it all at once
Old Jun 8, 2015 | 03:57 PM
  #1712
bucko72's Avatar
bucko72
sorry, i have been out of town and havent been on in a while.
http://www.vtwinaudio.com rear speaker connection vtua14 used this to run signal to rear speakers ,vtt014 amp turn on wire.
cycle sounds amp 4405-0263-3, speakers 2120-0147 2sets, speaker grills for fairing 2120-0168, magic box 4405-0265F you will need rca y addapters to split signal from magic box to the amp and a power and ground wire 8 guage with fuse to wire power to the amp. run new speaker wire from amp to front speakers. i think that is everything. hope this helps. let me know how it goes for you.
Old Jun 9, 2015 | 05:20 PM
  #1713
Ultra2014's Avatar
Ultra2014
6th Gear
Decided not to go with cycle sounds. The first thing I asked the guy was " is your stuff plug and play, I don't want to splice into the factory wiring"
He assured me it was. Then he wouldn't send me a quote, just kept saying it was around 800.00. After looking at their website and noticing their wiring harnesses had open wires for splicing. I asked Ed about it and he said we are done talking. Be careful!!!
Old Jun 9, 2015 | 05:39 PM
  #1714
UltraNutZ's Avatar
UltraNutZ
Leopard never changes it's spots.
Old Jun 9, 2015 | 05:40 PM
  #1715
UltraNutZ's Avatar
UltraNutZ
Call BT, order up what you want, find out what exactly is not plug n play. Then call Alan over at VTwin audio and if he don't already have any harnesses you need, he'll make them for you.
Old Jun 9, 2015 | 07:51 PM
  #1716
Ultra2014's Avatar
Ultra2014
6th Gear
The problem is I'm not sure and I'm beginig to lose trust in all of these people, I specifically ask and they tell me it is and I find out by looking its not. Its not that I don't know how to use a solder gun and shrink tube its just, if your going to lie about that, what else are you lieing about...
Old Jun 9, 2015 | 08:39 PM
  #1717
UltraNutZ's Avatar
UltraNutZ
Don't lump them all into the same pile of chit my friend because of a bad experience with a guy I've warned people about for years. They really are not all the same and there's a lot of people here to back that statement up.
NO ONE at Biketronics will ever lie to you, I can assure you of that! Bill and his crew will tell you straight up the good with the bad on everything you're trying to do and everything they sell. I can tell you personally with literally hundreds of installs I've done on bikes regardless of brand and regardless of price; not 1 single setup out there is 100% plug n play - no way, no-how I don't care what anyone tells you. You are going to have to run power and ground wires back to your battery whether you like it or not.
You do have other options as well (in no certain order) besides the clown you mentioned above.
Arc Audio
Biketronics
Hogtunes
J&M
Bagger Nation
VTwin Audio
Dragonfly Cycle Concepts
among a few others.
Old Jun 9, 2015 | 08:47 PM
  #1718
Ultra2014's Avatar
Ultra2014
6th Gear
Arc Audio
Biketronics
Hogtunes
J&M
Bagger Nation
VTwin Audio
among a few others.
Thank you sir. I haven't been on here long but it seems from what I've read, you really know your stuff. I don't mind running wires for power, ground or signal. Just don't want to cut into the factory harness if I don't have to. I installed the acc. Switches on my dash to run LEDs so I can do it I just want to keep it as clean as possible. And when I don't get the truth on the wiring, I start questioning fitment and functionality.
Old Jun 9, 2015 | 08:55 PM
  #1719
UltraNutZ's Avatar
UltraNutZ
many folks have their favorite vendors for things. I honestly don't have a favorite for audio, I stick with what works, what works well, and what's proven. When I call Bill or Robin for advice on something for example the 2013 CVO Roadking, they speak truths. Hell they themselves hadn't a clue as to how to get around that crappy sound system installed on those bikes. Robin and I worked together through email and phone calls until we got it figured out. Now those CVO owners have options as well without losing their iPod and it's controls.
I can sincerely tell you from past experience and then finally meeting him in Cincinnati earlier this year, you should question EVERYTHING about Ed and Cycle Sounds.
Old Jun 9, 2015 | 08:57 PM
  #1720
UltraNutZ's Avatar
UltraNutZ
also FWIW, whatever any vendor doesn't have to make your system of choice 99.9% plug n play, then Alan at VTwin Audio is your man. That guy works wonders with wiring harnesses, including special order stuff.
*EDIT*
Just noticed you're a neighbor.
